Question about GE 7-4853 Clock Radio
I have a GE 7-4853A clock radio with an auto-dimming display. The problem is that at night, the display dims until it's unreadable. How can I adjust it to be just a little brighter? There is a switch to turn off the auto-dimmer, but then it's so bright, it lights up the room.
eagle338
  • 4889 Answers
SOURCE: Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Posted on Jun 26, 2008
  • 54 Answers
SOURCE: Front panel with the clock settings is dim.
The only way to brighten is to replace the ERC or computer
Posted on Jul 03, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE JVM 1650 Microwave Night Light does not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 14, 2009
SOURCE: Curtis CR4966 LED dim
Needs new capacitors
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Posted on Apr 10, 2009
breddi2
  • 126 Answers
SOURCE: Surface lights are not turning off and stay on Bright. Any thoughts on how to fix this?
Unfortunately they are controlled by the circuit board and it is not repairable. The board will have to be replaced.Depending on age of unit you should call manufacturer and see what they say < might repair free>
Posted on Apr 22, 2009
Gaggenau oven display clock unreadable.
The display may have to be replaced
Sep 01, 2016 | Gaggenau Ovens
How do i replace burned out lightbulb in my in my cambridge soundworks cd - 740 clock radio ?
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mar 10, 2014 | Cambridge Soundworks CD-740 Clock Radio
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
My Timex t600 clock radio too dim. Love it, but I'd like to see it at night... Brightness control is at maximum...
Hello
The backlight LED of your Timex clock has got weak. It should be replaced. But it is really a skilled work as, you have to disassemble the display unit. If you are aware in electronics and have skill to do this work, you can do it by yourself. Otherwise, it will be best to get it replaced by any experienced service technician. OK.
Nov 20, 2011 | Timex T433 Clock Radio
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
The display is too bright at night. anyway to dim
Sorry this one was not built with any dimmer opportunities.
Sep 28, 2009 | Starlite Next Play Clock Radio with iPod...
Turn lights on and radio and clock dim.( 96 cougar xr7 3.8 )
they should dim unless they are unreadable check the dimmer control at the headlight switch
Jul 06, 2009 | 1996 Mercury Cougar XR7
Radio display is dim during night
Sounds like you have a dimming switch problem. You can pull the switch out, any I'd bet you have a burnt wire at the connector. It's a comman(<spelling?) problem.
Jun 19, 2009 | 2003 Chevrolet Monte Carlo
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
GE 7-4853 Clock Radio Logo
116 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
