Question about Toshiba 65HM167 65" Projection Television
Yellow lamp light is coming on, but can't get a picture what is wrong?
    Genius:
  • 1,126 Answers
The lamp is probably the problem, it needs replace. The lamp can even look good, but those lamps build up a internal resistance and they will get to the point where the tv takes a long time to come on, or will not come on at all.
Posted on Nov 11, 2010
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
LG tv has no picture
Your lamp most likely failed. You can get a new bulb for it for less than $100. RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG RU-52SZ51D 52" Rear Projection...
I have a 50PL9220D DLP 50". Original problem was picture turned blue and had humming noise. Replaced lamp. Now have humming noise and picyure will come up fine for 5 sec then picture goes out. I have...
Sounds like the unit is going into a thermal protection mode. Probably something wrong with a transformer.
http://www.support.philips.com/support/service/service_page.jsp?userLanguage=en&userCountry=us
Jan 07, 2014 | Televison & Video
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I need a fuse box diagram for my 95 dodge dakota
Fuse 1: 30A, Green; A/C Heater Motor Fuse 2: 30A Silver (Circuit Breaker); Power Windows Fuse 3: 15A Light Blue; Overhead Consule, Day/Night Mirror, Reverse Lamps Fuse 4: 5A Tan; ABS (There is not on in the picture) Fuse 5: 20A Yellow; Power Door Locks Fuse 6: 20A Yellow; Horn Relay, Instrument Cluster, Radio Choke Relay (on Premium audio system) Fuse 7: 10A Red; Buzzer Module, Stop Lamps Fuse 8: 20A Yellow; Headlamp Switch Fuse 9: 15A Light Blue; Cigar Lighter Fuse 10: 20A Yellow; Windshield Wiper Fuse 11: 20A Yellow; Turn Signal Fuse 12: 10A Red; Radio Fuse 13: 4A Pink; Recives power from Fuse 8 to power instrument lights (such as the cigar ligher lighting, ash tray light, dash lights, radio lights, etc.) Fuse 14: 15A Light Blue; Instrument Cluster Fuse 15: EMPTY Fuse 16: 5A Tan; Buzzer Module, 4WD Indicator Lamp, Tranny O/D Switch, Tranny Oil Temperature Sensor Fuse 17: EMPTY Fuse 18: EMPTY Fuse 19: EMPTY Fuse 20: 25A Natural; Park Lamp Relay, Off Road Lamp Switch (There is not one in the picture, I believe this is only on vehicles with fog lamps)
NOTE 1: Fuse 3 and Fuse 14 provide power for the Airbag Control Module Cavities 2, and 1, respectivly. NOTE 2: Fuse 4, Fuse 7 and Fuse 11 provide power for the Controller ABS Brake Cavities 7 and 12, 9, and 3, respectivly.
Under Fuse 4, 8, and 12 is the Buzzer Module (Black rectangle in the picture) Under Fuse 16 is the Hazard Flasher (Silver circle in the picture) Under Fuse 20 is the Horn Relay (White plastic looking in the picture) To the side of Fuse 17 and 18 is the ABS Warning Lamp Relay (Open cavity in the picture) To the side of Fuse 19 and 20 is the Turn Signal Flasher (Blue circle in the picture) Between the Turn Signal Flasher and the Horn Relay is the Time Delay Relaly (the other Silver Circle in the corner, in the picture
Dec 16, 2009 | 1995 Dodge Dakota
I have a Hitachi 50vg825 and the picture is a yellow cast to it what wrong?I just replaced the lamp.
Sounds like your light engine might be going. Hope u still have warranty. Usually pretty expensive
Apr 22, 2009 | Televison & Video
Yellow picture on kds 55a2000 sony projector
Could be the optical block. Did you use an original Sony lamp? Was the picture OK before you replaced the lamp?
Oct 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced lamp and still no picture.
Does the red indicator flash or blink? How many times it blinks is a error code that tells a liitle about what is wrong. For instance, 3 red blinks means the air filter for the cooling fan is restricted and needs to be cleaned.
This model has lots of complaints against it, get it working and then put it under an extended warranty.
Hope Ya Fix it!
Jan 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Toshiba 65HM167 65" Projection Television Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
