Question about Libec LS22M Professional Tripod System with T58 1Stage Alloy Tripod H22 Fluid Head MS1 MidLevel
The H35 head on my Libec 58 tripod needs to be replaced. I want a head that has an adjustable fluid pan. The H35's pan is fixed and slow as molasses in winter. I want to pan fast and slow. What head can do this and fit on my Libec T58? Thanks!!
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Libec T58 Tripod
I had a Porter-Cable that I was able to repair using three small pieces of lexan and a bandsaw. I took off one of the latches that were good and traced the pattern on the lexan and sawed out the handles. Cleaned them up with sandpaper andthen stacked them and drilled out the holes. Then I drilled two more holes for clearance for two 6-32 machine screws and nuts. Put the whole thing together and installed it - still working after four years.
Posted on Aug 22, 2007
How can I replace the quick release head for the libec th659dv tripod. A student has lost the plate but UK retailers do not seem to stock libec replacements.
Try a plate from another tripod. I have three different tripods, and the quick-release plates are all interchangeable.
Jul 08, 2015 | Libec Photography
Can you suppy a new Heiwa TH-650 Head only?
Please visit a (online) photo store, perhaps even eBay or Amazon, and try to get the head there. We don't sell stuff, we only try to answer questions, from all over the world.
Sorry.
Jan 30, 2015 | Libec Photography
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
What fluid do i need in my 3066 tripod
they don't use fluid - maybe some grease in the tilt and pan of the head, but the tripod itself doesn't need any.. you might need an adjustment somewhere... I own 3 of these.
Feb 07, 2013 | Manfrotto Bogen 3068 Tripod With Bogen...
Fluid head platform is moving before the fluid
Below the head where it attached to the center column is a set of three screws. Back them out a little bit and then tighten the head, then screw those three grub screws back in to lock the head.
Apr 04, 2010 | Bogen Communication Bogen Manfrotto 3046...
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
High hat for Libec T98C
Try the site www.transfilm.com they are a repair facility and reseller of used equipment and might have what you are looking for.
Aug 03, 2008 | Libec Photography
Libec THM20
The leg is slightly off the track, which is a curved piece which fits along the tripod support rail. If you're not careful when collapsing the legs you'll force the leg to go off-track like this.
Sep 07, 2007 | Libec ST30 Tripod
Libec T58 Tripod
Aug 21, 2007 | Libec LS-55 Aluminum Tripod System -...
Pan control not fluid when tension increased
Sounds like you might have gotten some dirt trapped under there. You might try to loosen it and blow it clean.
Apr 16, 2007 | Sunpak Video Pro M Tripod
Libec LS22M Professional Tripod System with T58 1Stage Alloy Tripod H22 Fluid Head MS1 MidLevel Logo
242 people viewed this question
Top Libec Photography Experts
Tony
Are you a Libec Photography Expert? Answer questions, earn points and help others
