Question about Samsung WF448AAP Front Load Washer
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't know. I took the cap off the filter and had a lot of water come out. I cleaned the filter out and started it again and it eventually had the same warning, to clean the fillter. I removed the filter a second time and a crazy amount of water drained out. The filter was clean but somehow it is not draining. Can someone help. Thanks
    Top Expert:
  • 867 Answers
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
Posted on May 15, 2017
3 Suggested Answers
  • 5 Answers
SOURCE: Samsung WF448AAP chimed and read to check filter.
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Posted on Nov 12, 2010
SOURCE: I have the Samsung WF448AAP/XAA
I have the same problem. Did you manage to get the spring back on???
Posted on Nov 21, 2011
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
Washer begins filling in short bursts for a few seconds and then stops and does nothing.
The unit has probably not drained and sensors are telling it not to add water. On the front of the machine is a door near the bottom that you remove and you can see the filter cap behind that door. If you remove that you can clean the filter. However, you will get lots of water all over the floor. So be ready with a vacuum cleaner that can handle water.
Sep 25, 2015 | Samsung WF448AAP Front Load Washer
I have a WF448AAP/XAA washer and is leaking from the bottom, what it be?
Could be the bottom seal of the drum, a leaky hose or the pump that discharges the water out of the drum during rinse cycle. If it seems to leak while filling and/ or operating my bet would be the drum seal.
Nov 27, 2014 | Washing Machines
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
WILL NOT DRAIN
Check the drain pump and drain filter. It is on a small compartment on the front bottom of the washer.
Jan 12, 2014 | Samsung WF448AAP Front Load Washer
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Samsung WF448AAP Front Load Washer Logo
252 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
