Question about Belkin F5D7234-4 Router
I have Belkin F5D7234-4-H V5 Router and I have one computer connected by cable and laptop connected by wireless. Computer on cable have constantly connection to the internet, but time to time laptop losing connection on internet and on router is bliking orange colour on "wireless" or sometimes it doesn't light at all. After couple seconds is the "wireless" light on router again green and the laptop is connected again. Can you help me? Thank You
    New Friend:
  • 29 Answers
Go to http://setuprouter.com/router/belkin/f5d7234-4v5/login.htm and then follow the instructions following: Login to the Belkin F5D7234-4v5 Router and work your way down through the instructions.
Posted on Jun 12, 2017
SOURCE: Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Posted on Feb 26, 2009
  • 50 Answers
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Posted on Apr 21, 2009
rockitman187
  • 2559 Answers
SOURCE: conect the router?
1. Unplug your DSL modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router.
2. Connect the new cable (provided in the box) to the yellow
port on the Router.
Plug the other end into the modem.
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer.
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
Posted on May 17, 2009
etaf
  • 779 Answers
SOURCE: belkin F5D7234-4 i have great connection but
  1. A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. and what channel they are using. If you are also using one of the same channels it may be interfernace - Have a look at the channels being used - loginto the router and change channel to one that is not used - try and use channel 1 or 6 or 11
  2. Wireless Security:- Loginto the router, this may seem difficult, but its really straight forward, - however you will need to know how to login into your make of Router - A manual cna be found here http://en-us-support.belkin.com/app/product/list/q/routers/ choose, G in first drop down and then the model in the second dropdown. That will explain how to login. Once you have logged into the router main page, goto the wireless section and remove any wireless security, this maybe a simply as a box and click disable. --- Now see if the machine run faster on the wireless. This may be a direct link to the manual http://en-us-support.belkin.com/app/product/detail/p/387
  3. safemode:- Try to boot the PC into "safe mode with networking". To do this switch the PC on and now as it starts keep tapping the F8 key untill a menu appears, from that menu choose "safe mode with networking". If that now connects at a fast speeds - post back a comment and if that's the case, We can try doing a "clean boot" and try to identify the startup or process that is causing the issue
  4. It may be you need a firmaware upgrade from here http://en-us-support.belkin.com/app/answers/detail/a_id/301 also includes instructions on how to do the upgrade. This may be a direct link to the firmware http://en-us-support.belkin.com/app/product/detail/p/387
Posted on Mar 24, 2010
  • 2340 Answers
SOURCE: I AM USING A BELKIN G WIRELESS ROUTER MODEL F5D72...
Either you have not configure the Wireless SSID or your router is faulty. You can use the easy setup using the CD or configure the router by going to the default IP address. Do read the setup manual first.
Posted on Jun 01, 2010
Have modem connected to desk top. need instructions or manual to connect belkin router to modem to also receive wireless for laptop.
Connect a LAN cable from Belkin to yourlaptop/computer's LAN port, open a browser on your laptop/computer and enterthe Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 24, 2011 | Belkin F5D7234-4 Router
Dear Sir , i have belkin model no. F5d7234-4H v5 G wirless router, my installation CD lost, Sir How can get these driver CD, can you send link driver,
Connect a LAN cable from Belkin to your laptop/computer'sLAN port, open a browser on your laptop/computer and enter the Belkin'sconfiguration URL. http://192.168.2.1
May 24, 2011 | Belkin F5D7234-4 Router
Hi, reallly dunno,l i just conect my belkin router how i should conect and what is the problem. my belkin cant find a connection to computer, but i still have a connection. thanks for any solution
May 23, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can u tell me how to get my wireless router connected to the internet. I keeps telling me there is no internet connection
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings. Connect a LAN cable from your DSL or cable modem to the Belkin's WAN/Internet port.
May 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a Belkin F5D7234-4 v3 wireless router. I was wondering, is there any way to either upgrade to a different firmware version such as the v4, or just a simple way to make it more a wifi receiver?
You cannot upgrade v3 to v4 or v5. Belkin routers are junk, because once they come out with a new version you will never see a fix for your router. You have to go buy a new router if you want better access to the routers settings. You are better off buying another brand like I did. Belkin blows.
Jan 12, 2011 | Belkin F5D7234-4 Router
Connect my office computer to belkin wireless
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 06, 2010 | Belkin (F5D7230-4) Router (587009)
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin F5D7234-4 Router Logo
305 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
