Question about JVC KD-S640 CD Player
Rndyrb9reads disc for few seconds then ejects
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
I put a disc in my sanyo DWM 400 and the doorwont open to eject it or get it out.
Have you tried unplugging the player, waiting a few seconds and then plugging it back in? Sometimes that works.
Dec 20, 2014 | Sanyo DWM400 DVD Player
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
Disc drive wont open. i pressed the eject button on my keyboard but it makes a clunk sounds but wont open.
This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions: To eject a disc with Open Firmware commands, follow these steps:
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
  8. Your computer should now start up normally.
  9. Instructions curtorsey eh.mac.ca
Aug 16, 2010 | Apple iMac G4 Desktop
How do i eject a disc from my dell laptop
  • Go to "My computer"
  • Then se where the disc is inserted
  • Right click the drive and look for the "Eject" option in the list
  • Click on it and in few seconds your disk will come out
If you dont want to do it like tis then press the eject button near the cd tray on the laptop
May 20, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Disc not ejecting
Try the force eject (holding down the eject button for a few seconds until you see the blue light flash consistently) if that does not work try switching the power switch at the back ON while pressing the eject button at the same time causing the fans to blow at maximum rate & might eject your disc (Only let it blow for a few seconds on max power otherwise this could potentially burn up your graphics card!)
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Disc is stuck inside goes on will not eject or
You will find a small whole in front of the disc. Quite small, say a niddle head size just take a pin approx 3 inches and poke it slowly inside. You shall feel the pushing of a soft touch feather button like on your keyboard and your CD will come out. Don't forget to push eject button before poking the pin. and kindly do rate my solution.
Jul 17, 2009 | Nintendo Wii Console
Game stuck in console
Try thees steps
Turn the Wii.html#" target=_blank itxtdid="7750962">Wii off and on again after about 20 seconds. Press the eject button again. 2
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. Hold down the eject button for 5 to 10 seconds. 4Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. 5Call Wii.html#" target=_blank itxtdid="7751052">Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds Good Luck
Jan 23, 2009 | Nintendo Wii Console
You have been removed from game for ejecting game disc
Try taking an air compressor (if you have one)and blow out the disc tray carefully. if no compressor try a vaccuum on reverse mode
Mar 01, 2008 | Sony PlayStation 2 Slimline Console
JVC KD-S640 CD Player Logo
12 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
