Question about Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum
Samsung RS267TDRS Refrigerator -- no water coming from door dispenser. Water line to back of fridge works fine. Water filter inside fridge fills with water, and it makes ice like clockwork. But no water comes out of door dispenser. We got a few trickles after it was installed, but that slowed down to drips, and now nothing at all. Is it possible the line inside the freezer door is frozen? Any other suggestions? The local warranty repair guys couldn't fix it, and Samsung said they would not ship us a new door -- offered to replace the whole fridge, but we declined and took the full refund instead (got to keep the fridge for free). Even so, I would like to get the water dispenser working if possible. Thanks in advance for any help you can give!
  • 441 Answers
The most common reason water stops are 1. The water line has frozen, but its not the part in the freezer door. Behind the crisper bins in the fresh food section, you might not see it but it behind the back wall. Heat up that area with a hair dryer, or if its not full shut it off for 24 hours and it will do the trick. 2. The pump that sends the water to the dispencer is dead, it will be located behind the ref lower left hand side behind panel (follow the water line) part # DA74-40149D, you can order it at marcone.com for about 27.00
Good luck, if those dont work let me know
Posted on Nov 11, 2010
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
I have mold that has formed in the water lines of my refrigerator. What can I do to fix this problem.
It is best to replace the line inside the door that goes to the pressure handle. Check the inside of the water supply line at the back of the fridge to insure it doesn't have mold. A chlorine solution will kill the mold but will leave the lines stained black inside. Installing a filter in the fridge line, some fridge makers sell them for their units helps prevent mold spores from getting inside the water lines. In most cases, only the small, short water line in the door tap is all that is affected.
May 29, 2015 | Samsung RFG298HDWP 29 cu. ft. French Door...
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Samsung refrigerator dispenser makes noise after filling water glass
You may need to have the water filter replaced. This sounds like it is starving for water as it refills.
Feb 03, 2013 | Samsung RFG297AA (285 cu ft) Bottom...
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Water not dispensing from side by side fridge
check the primary water valve ,does it make a noise when you push the dispenser ?
Mar 29, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water won't come out of the fridge when the button is pressed. I thought it was because I needed a new filter but that's not it I changed filter the fridge is making ice fine, but no water from the...
most likely the water line that supplies water inside the freezer door has frozen up blocking the dispenser. try leaving the freezer door open for 5-10 minutes and allow the line to thaw out.
Jul 04, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum Logo
1,462 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
