Question about Lexmark X4530 InkJet Printer
I'm getting streaking on my paper when it prints. Does my printer need cleaning and how do I do that.
    Genius:
  • 1,087 Answers
Sounds like the cartridges needs cleaning. You can do it on the printer by pressing Settings button -> Maintenance, hit check-> Clean Cartridge, hit check. It will print the "clean cartridge" page and this will help clear the nozzles on the cartridges and improve the print quality.
Also try to check the cartridge ink levels. Press Settings button -> Maintenance -> Ink Level.
If problem continues, try to insert a known working cartridge to determine if your other cartridge needs replacement. Thanks.
Posted on Nov 12, 2010
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
Use a hp deskjet 35200(3500). when unit is printing all lines are blurd and paper gets black streaks all over. The printing is unreadable and smudged.Is there a manner to clean this up?
Streaks:Cleaning interior
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it
Feb 06, 2011 | HP Office Equipment & Supplies
How can I cure streaking on the reverse of the paper? Epson S20.
streaking on the reverse side suggest dirty rollers.
1. remove cartridges form the printer
2. disconnect all cables
3. check full paper path for presence of debris, lint, bits of paper, remove if necessary (you can put printer on it's back or sides for esy removal)
4. mount on long skewers lint free clothing or tissue
5. wet tissue/cloth in isopropyl alcohol and whipe all rubber rollers on paper path till no discoloration to the tissue
6. connect all cables
7. insert inks and print test page
if necessary, you need to clean rollers again, but once is usually sufficient. to keep printer in good condition, you need to print at least one page per week and periodicaly clean the rollers, that depend on amount of printing done.
Jul 28, 2010 | Epson Printer
Printing streaks on all faxes I recieve
clean the rollers in the paper path
Please rate my help++++Thanks for using FIXYA
May 07, 2010 | Canon MX300 Office All-In-One Printer
Phaser 3200 mfp laser printer leaves streaks on paper. First sheet is okay then rest get worst as printing continues.
One of two things.
If the streak is a line. No visible print in the streak, Then most likely the drun cleaning blade is bad and the drum unit will have to be replaced.
If the streaks are sort of reprint. a faint reprint of what is already on the page, then you need to replace the fuser.
Mar 25, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
I'm getting a streak of ink down the paper
change a toner.
when you have the toner out. clean the heater element (glass). make sure the printer is off and the heater element is cool before you do this.
May 14, 2009 | Dell 3100cn Laser Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Streaks on left side of paper when printing in color
go to the control panel and then printers and fax. double click your printer and click on the tab and button to "clean print heads". after doing this, click on "align print cartridges". this will fix the streaking problem you have
Feb 25, 2009 | Dell 5100cn Laser Printer
DeskJet 9800 Streaks in Color Print
That is the problem, you need to expost the track wheels and clean them with a paper towel soaked in rubbing alcohol.
Jun 27, 2008 | HP DeskJet 9800 InkJet Printer
Lexmark X4530 InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
