Question about Nokia BH-104 Bluetooth Headset
Nokia bluetooth device unable to connect my computer..always blinking green light please can u explain about these problem thank u very much sir, regards, sridhar
Hi
first hold start button for 8 to 10 second...when it start blinkin then open bluetoth device and click ADD tab. and search your device.when it will appear,it will ask for a unique pass.then choose your pass key.PLEASE MIND THAT THE PASS KEY MUST BE FOUR TIMES ZERO (0000) and then ok.it will connect......
Posted on Dec 08, 2010
  • Unidentify Mar 20, 2011
    I Have Done The Above Steps But Still Cannot Connect With It.
    The Steps Which You Told Is For Adding A Bluetooth Device.
    What About Connecting To It ?
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
Sir I buy bh-105 bluetooth for N73 But can not connect.
Please follow the below steps to connect your head set to mobile.
1. Ensure that your mobile device is switched on and the headset is off.
2. Press and hold the power key of headset for about 5 seconds until the green indicator light starts to flash quickly.
3.Activate Bluetooth connectivity on your mobile , and set it to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. If necessary, enter the passcode 0000 to pair and connect the
headset to your device.
When the headset is connected to your device and is ready for use, the green indicator light flashes about every 5 seconds.
Thank you
Aug 07, 2010 | Nokia N73 Cellular Phone
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
My nokia bh 213 bluetooth was working with nokia E63 , all of a sudden it is not , the bluetooth is charged and green light is flickering , when tried to pair thed eivce it says the device not found , what...
Thanks sleekycupid.. Even i had a same problem just followed the steps you said.
Step 1: Switch off the bluetooth device.
Step 2: Charge the bluetooth device.
Step 3: Then hold the device button till the green indicator blinks faster than normal.
Step 4: Now try to pair the device from your mobile.
Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3.
Enjoy!
Mar 13, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Blinking red and green
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
My LG cookie is not able to detect the Nokia Bluetooth headset
Sorry if you have done this but let's see if we can get you connected!
On your Nokia headset press and hold the multi-function key for roughly 8 seconds. Your green light will begin to flash quickly. Your Bluetooth headset is now in pairing mode.
Now using your LG Cookie, press Menu > Settings > Bluetooth > Search
Once found, you will need to type the pass code which is normally set as four zeros (0000).
You should now be connected.
We hope this helps!
Jul 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Nokia BH-104 Bluetooth Headset Logo
607 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
