Question about Jenn-Air JES9800A Electric Kitchen Range
My stove is saying f9 and constantley beeping what do i do
  • 2 more comments
  • Anonymous Jul 26, 2008
    my oven keeps saying f9 and iis constantly beeping i accientally hit the clean button
  • Anonymous Nov 14, 2008
    f9 code
  • foxwood7 Nov 27, 2008
    error code f93 when self clean is turned on
  • DCordova46 Jan 03, 2009
    My door will not unlock now. I had to unplug the stove to get the beeping to stop but now the darn door will not unlock at all
If you hit clean Button, try to Cancel it.
If it's beeping... and see F9, I tried to push in the door... and the "lock" was clear..... and the door was opened.......
I thought i will share this w/ you...
Posted on Jan 12, 2009
My stove has a flashing door locked light then an f9 message followed by a continious beep
F9 is an Internal Logic Failure - Check door latch and Latch switches and replace if defective. Replace control board (clock) if everything else is ok.
Oct 06, 2009 | Kenmore Kitchen Ranges
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a fridigaire stove self cleaning model fefl77abf i pushed the cleaning button it said it was locking the door then the stove started beeping and flashing f9 and the door is not locked could you help...
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Feb 01, 2009 | Kitchen Ranges
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
F9 door locked
This means that the door latch motor assembly is broken.. I too am having the same problem.. And I am hosting easter dinner.. I am screwed, the part alone is about 100.00, http://www.applianceblog.com/mainforums/archive/index.php/t-6539.html
Mar 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
My frigdaire stove door finally opened manually from behind but
F9 code: An F9 code indicates the EOC has detected a problem with the motor door latch assembly. Check the contacts of the lock switch, wiring to the lock motor assembly, and the lock motor.
Dec 16, 2007 | Frigidaire FEF455BB Electric Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
390 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
