Question about Honeywell HWM-260 Humidifier
I have a Honeywell HWM 260 (I think thats what it is) which I have had for a few years. This is the first time I have used it this winter - probably 9-10 months since last used. I filled it with water and pressed the Power on button but nothing has happened even after 10 mins. All I get is a little icon on the screen which looks like a container with a water drop inside it.....what am I missing or doing wrong?
4 Suggested Answers
SOURCE: Humdifier wont work
I'm having the same issue
Posted on Jan 22, 2010
carlweed
I had two Honeywell HWM-260 Humidifiers with the same problem; the blinking "Refill Symbol" appearing for no reason, and a stubborn "Reset" button. Even when it would reset, the Refill Symbol would soon appear again, turning the unit off.
The problem with both units was the "Tank" safety switch; a small, lever-actuated micro-switch inside the "Power Unit." I wasn't able to find any replacements, but I did find that these little switches can be disassembled, so I took them apart and delicately cleaned the contacts. Now both humidifiers are working fine again.
I was initially thinking about just jumpering the switch terminals, since the tank safety switch seems rather superfluous anyway; the humidifier having a thermal shut-off that will turn it off if the tank runs dry (or isn't in place.) If I hadn't been able to clean the switch contacts, I probably would have settled for that.
Posted on Dec 17, 2014
  • 85 Answers
Check the thermo protector fuse at the bottom near the heating pad. The fuse must not be open circuit. If it is, replace it. You can order the fuse for $1 from eBay or Amazon. Good luck!
Posted on Dec 30, 2016
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
I lost my operating manual and would likd to download the instructions if possible
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 07, 2010 | Honeywell HWM-330 3 Gallon Humidifier
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Humdifier wont work
Jan 18, 2009 | Honeywell HWM-260 Humidifier
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Dec 19, 2008 | Honeywell HWM-450 4 Gallon Humidifier
Honeywell Warm Mist HWM-2030 how to clean it ?
Just uploaded the user manual to this site, which contains the cleaning instructions. You may also download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
Nov 23, 2008 | Honeywell Warm Mist HWM-2030 Humidifier
Manual
I lost my manual as well but found this link to a pdf version in case anyone else has the same problem finding it as we did. http://www.appliancefactoryparts.com/content/pdfs/113129.pdf
Dec 18, 2005 | Honeywell Warm Mist HWM-255 Humidifier
Honeywell HWM-260 Humidifier Logo
170 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
