Question about Iomega 1TB Desktop USB 2.0 Hard Drive
I have been using this hard drive with this computer for a couple months now buut this morning when i plugged it in my computer was telling me i need to format it to be able to use it. and i know its already been formatted because you cant put data on it if it isnt. i have almost 500 gb used up and i dont want to reformat it because doing so will erase all of it. is there anything i can do?
  • 3,267 Answers
Best solution would be to try it on another computer & if it works there use the windows check disk tool (& maybe the defragmenter) to correct this problem. OR you could transfer the data onto another hard disk, format this one keeping 2-4 partitions and reload your data.
Posted on Nov 11, 2010
I bought this laptop hp dm4-1160-us a month before..after some days i encountered a problem of booting. i generaly use my laptop in the night..frm some days i use ma laptop in the night and after using it...
From what you describe, the issue only occurs when the system has not been used for a while. My impression is that the hard disk drive is slow to come up to speed when cold, and this may require a couple of reboots for the drive to get up to speed. Once booted for the day, it will likely continue to work.
Eventually, the drive will get slower and slower and over time stop booting.
Recommendation: Back up any important data and replace the hard drive.
Jul 27, 2011 | HEWLETT-PACKARD HP Pavilion DM4-1160US...
I have a Maxtor 1Tb External Hard Drive that I have only used a couple of times on my PC - I did a full back up a few months ago and all was well. I added a couple of things to it a couple of months ago...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 09, 2010 | Computers & Internet
I have a mac Book Pro and have been backing up my photos to a WD Passport external hard drive for several months now. This morning the Passport did not even show up in the finder window. Its' Smartware...
Try plugging into another computer and if that works save all your data then format and try back on your own computer. If this doesnt work start to look into data recovery software. I use 1 called GDB (Get Data Back) which will read a lot of drives information when operating systems wont. Good luck from Scott
Jul 12, 2010 | Computers & Internet
After i plug in my drive, the light comes on but does not register on my computer. All indications say that it is working but i can not access the drive. The drive was working on the same computer just...
It sounds like the controller board on the hard drive itself went out, I had this problem not but a couple days ago on one of mine. I would take it back to the store for an exchange if at all possible.
May 25, 2010 | Western Digital Passport 320GB External...
I have the 1TB wd my book, randomly it isn't recognized on my computer anymore. My computer tells me a problem occurred on hardware installation. I have been using this for 6 months now
The randomness of your problem makes it sound like a power issue. Try plugging it in as the only USB item (if you need to leave the keyboard and the mouse) those are ok. However, don't have speakers, etc.
Also try different USB plugs.
Also, you might want to use a power supply on the drive. If you already have one, can you find one that will give you more amps?
Otherwise, you might try another drive in the case to see if the controllers are working for any drive.
Write back if I can help you further. Also, if this helps, please vote.
May 23, 2010 | Western Digital My Book Essential 1TB...
Hard Drive not accessible, now not recognised by computer
Do you have another computer you can plug it into? The problem could be with your USB. If it is, see what updates you installed and then removed that may have affected that. You can also go to the manufacturers web site and download the original firmware or updated firmware files.
Dec 12, 2009 | Maxtor Hard Drive
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Bought 500Gb two months ago,greatproduct.My wife has put 4 months of college photography on the hardrive and has had no problems retrieving.Suddenly two nights ago stopped working,power light is on...
Plug it into a friend's computer (in the same cables as his main drive) (Turn the system off and pull the plug out first!) Tell us if it works there.
Data loss happens all the time for various reasons. That's why you need to learn how to use a CD burning program to transfer the pictures to CD's. If you don't want to burn often, get yourself a 16GB little flash drive at least.
Mar 12, 2009 | Maxtor Hard Drive
New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Jul 16, 2008 | Western Digital My Book Premium ES...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
42 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
