Question about Sander Industrial Original Clarke Floor Drum Du-8r
How to take drum off of a clark 504 floor sander
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I have a Clarke Model 504 floor drum sander.
I would recomment trying a local rental yard. they usually have the paper and machines for rent. If not let me know and I will do some more research with Clarke, give me your general area with zip code and I will try and find a local source.
Posted on Jan 09, 2011
Ez 8 sanding machine will not start
Hi there
did it smoke or smell funny or did it just stop
either way check the drive/run capacitor that is usually
what will stop them from starting/running
Jul 15, 2014 | Clarke 07058A EZ-8 Floor Sander Expandable...
I have a Clarke Model 504 floor drum sander. where can i find paper for this?
Jan 09, 2011 | Sander Industrial Original Clarke Floor...
My belt sander is eating away to much on the left side and it is also leaving cut lines on the floor.. does anyone have a solution or a guide to how to fix this problem? my floor sander is a "Clarke...
I would first look at the discs for uneven wear but if you want and I would recommend going to "Clarkeamericansander.com" they hae service and support and technical services who can better serve you. they also have tool free numbers listed for assistance. where I work I have called them are they are really there to help. Good Luck
Sep 23, 2010 | Clarke Floor Sander Floor Sander Orbital...
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
The drum of my Clarke DU-8R got jammed with a metal bar (don't ask!) and the machine stopped running. After replacing the paper and restarting it, it doesn't have the same power. When I go to sand, the...
Check the bearings on the front drum. If you can remove the side cover and take off the 2 belts spin the drum by hand. It should spin freely. If it doesn,t the bearings may be going bad. Also check to see if the dust bag is inflating. There may be something plugged up in the exhaust tube leading to the bag.
Jan 13, 2010 | Sander Industrial Original Clarke Floor...
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
Using a Clarke DU-8R drum sander, I am getting grooves in the floor from one pass to the next, running parallel to the sanding direction. I am sanding right to left as it says. Is there an adjustment to...
If the drum has the bar clamp with the 3 screws make sure the bar is set so the screws are flush when tightened down. If you reverse the bar clamp the screws will stick up a fraction and cause this grooving in your floor.
Mar 02, 2009 | Sander Industrial Original Clarke Floor...
I have a du-8r clarke floor sander, i need a schurter switch, swiss made, a146f160u4-azm11, 120v, 16 amp. do they still make this part.
I can't find anything on Clarke's website for this tool. But if you have the switch out I would take it to a local repair facility or electrical supply house and have them match it up. There is usually nothing that special about the switches. Let me know if you cant and I will try and dig deeper.
Jan 21, 2009 | Sander Industrial Original Clarke Floor...
I have a clarke c-5 edger need parts
I checked Clarkes site and they don't show this tool. Suggest you call 1-800-253-0367 and ask for technical support. I deal with this company on a weekly basis at work and they are great in helping. Good Luck
Dec 13, 2008 | Sander Industrial Original Clarke Floor...
Sander Industrial Original Clarke Floor Drum  Du-8r Logo
155 people viewed this question
Top Sander Tools & Hardware - Others Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
