Question about Muratec Copier
Mfx-1450 My unit keeps asking me to open the side cover and remove paper. There is no paper. I have used compressed air and removed all moveable parts to clear it.
    Problem Solver:
  • 5 Answers
Clean the feed tires dale
Posted on Jan 23, 2009
My printer keeps saying paperjam. It's new only a couple days of having it set up. Nothing got Jammed..just used it a couple times. I tried opening the back department and there was nothing. It's a...
1) Open all the covers.
2) Remove ink cartridges and any removable parts.
3) Blast the guts with compressed air with special attention to the
areas where the paper moves over.
May 13, 2011 | HP Office Equipment & Supplies
My copier say open side cover and remove paper every time i try to print? Why is it doing this
Because it "thinks " there is a piece of paper jammed.
Open the machine make sure there is no jam, take out the paper cassette and check or change the paper for fresh paper...put the cassette back in and try to make a copy again. As a last resort try making a copy with a piece of paper thro the "by-pass" tray and see what happens.
Nov 16, 2010 | Muratec - MFX-1300 Copier
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I bought a panafax-uf790 about 2 years ago. Now I am having the worst paper jam problem. It would always stop at the same place and record paper jam. I've constantly remove the paper and it keeps giving me...
Just a suggestion, Try the following, obtain a compressed air canister, or a compressor filled with air, open the unit from where the paper feeds and ejects after printing, blow the compressed air through the feeder and the ejection side, turn the rollers if possible whilst doing this.
May 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Printer won't print
Try the following: Switch off and unplug the unit, 1) Open the unit and remove the covers that can be removed. 2) now look for any object or blockage in that unit, if none then move the moveable part with your hands, if it moves freely then close the unit after you cleaned it out with compressed air.3) Secure all removeable parts firmly and restart the device. If that doesn't help, I will try and find the correct solution for you.
May 12, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Samsung ML-2510 printer paper jam
This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
Aug 03, 2008 | Samsung ML-2510 Laser Printer
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Grill Fell out
Unfortunately i had found myself in this same situation. i have no idea how the grill came out when it was closed, but it was stuck in the fan enclosure underneath the counter. Unlike the poster above i did not have access to the side screws to take the unit apart. instead i was able to remove the front panel, and then unscrew the motor arm from the protective case, and unscrew the case from the unit. This created enough wiggle room that i could raise the right side of the vent cover up and extract the left side out the bottom opening. then it was just a matter of reconnecting the arm to the cover and the cover to the unit.
Good Luck,
-Mark
Nov 05, 2007 | Dacor Preference RV36 Kitchen Hood
Muratec Copier Logo
189 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
