I have a simpledrive 120GB that was working fine now it is not recognized. the USB works and it is getting power.
  • 1 more comment
  • William Bode Nov 11, 2010
    it has 2 USB's I tried to plug in bot, nada, no, no clicking... some times blue light comes on some times it doesn't.
    I am now traveling and I am on my Dell mini Hachintosh. running OS X journaled..
    are we connected? is this a live chat?
  • 13,433 Answers
Hi
Is your simpledrive a drive that works with only one usb connector or does it have a power adapter?
Has the drive been dropped or anything similar?
If you hold it agains your ear do you hear steady humm or clicking sounds?
Posted on Nov 11, 2010
  • Ekse Nov 11, 2010
    No, this is support over email basically.
    It sounds like the drive's casing is faulty, theres a small control board inside the casing that can go bad, you may have to replace the whole casing.
    another possible reason is that your laptop is not supplying enough power to it from the usb ports, since your cable has two usb ends make sure both are connected, try different ports, try a USB hub with a plug in the wall power adapter - but thats not a guarantee fix either.
    If the drive does the same in another casing, then its a problem with the drive itself, and we can do noting to repair it. Since its a mac drive it will be difficult to recover data from it, unless you can plug it inside a mac as a 2nd hard drive. if noting comes up there either then the only way to get something off of it would be to send it off to a real data recovery service and those are not cheap.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Simpletech SimpleDrive will not recognize on my computer, have tried it on another computer and even bought a new USB cable and new computer battery still no luck. I have years of pictures and videos on...
Not Enough power To Run The device Please !! Make sure your USB Is upgraded To The Latest or It wont Work!!! Need More Info !! Hope This Helps Donald Deane MCSE,ASE,CPO
Jul 27, 2017 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm SimpleTech SimpleDrive Portable USB 2.0 60GB wont show up
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 22, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I am not able tp acces files on my simpletech 120 GB as this drive is not recognized both on my laptop and desktop
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 09, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
My PC or Laptop will not recognize my maxtor one touch 111 120GB hard drive. it was working fine befor and now i get an error from windows that says: thre was a problem installing your new hardware
It is your driver related issue.
Check your operatign ssytem version is winxp sp2 ?
SP2 is perfact for usb 2.0
Also you can try to uninstall all usb driver and install inf update utility it is comes with motherbord disk.
You can uninstall usb drivers from computer with device manager .
For that go to my computer proeprty then hardware then device manager then uninstall all usb drivers.then restart the computer then check.
Also check your harddriver usb cable is working fine tryt all usb ports of computrer 1 by 1.
Also try in another computer.
Aug 24, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Simple tech drive
Using this program http://www.ridgecrop.demon.co.uk/dow...at32format.zip
Its worked perfectly on my 300GB usb drive, my PS3 can see it just fine
Oh and it works on vista as thats what i did it on..
Aug 01, 2009 | SimpleTech 320GB SimpleDrive External by...
ST-500 not recognized with Epson CX9400 printer
Printer is draining USB power resource. Add a powered USB hub and run drive off of that.
Jul 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleDrive Will not Run
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Sep 23, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
David Payne
David Payne
