Question about Electrolux EIDW6105GB 24 in Builtin Dishwasher
I have an electrolux dishwasher Model # EIDW6105GS1 that for the second time has stopped working and all the lights at the top control panel are flashing...what might this mean? I removed the panel down below the door and it appeared to be a drainage problem. The first time it happend was about 1.5 yr after purchase...(No more warrenty and no extended warrenty)...I drained the water in the pan below and it worked once again. After about a month I am having the same problem.
  • 15 Answers
SOURCE: Panel not working on Electrolux Dishwasher
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Posted on Apr 07, 2009
SOURCE: have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Posted on May 09, 2008
tattootech2
  • 72 Answers
SOURCE: Electroluxe dishwasher starts and once water runs
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
  • 530 Answers
SOURCE: I have a Firdgedaire Electrolux model GLD4355RFB1
what is the code?
Posted on May 17, 2010
SOURCE: Electrolux ewdw6505gs model dishwasher commd panel does not power
Read publication 5995509477 of Electrolux name factory Parts Catalog. You will see the POS NO 12 Part no 7154671401 name Latch Assembly, door w/shield. This relay stay open. a little bit of WD-40 and he working correctly.
Posted on Oct 28, 2010
My electrolux Dishwasher model ei24id30qs is beeping 3 times every 4-5 seconds and the drain pump ( or some motor of sorts) continues to run with the door open. Have opened the trhwn the breaker for hours...
I appreciate your post, kris!
From what you have explained your Electrolux dishwasher is beeping three times every four to five seconds. This could be a possible issue with your control panel. It may need to be replaced and this may not be a simple DIY job. If you need assistance locating a professional I would recommend reviewing your manufacturer's website for help. I hope this information is helpful for you. -Matt
Feb 11, 2015 | Electrolux Dishwashers
I have a EIDW6105GS1 all of the light flash! it did it once before and I thought I reset it somehow! but I cant remember! can you help?
There might be a possibility of resetting by pressing High Temp button 5 times. But I don't think this may solve the problem.
All lights flashing could mean a flood detection. This means water is leaking into the base of dishwasher. The flood switch has to be dried to make it work again. Also need to find the source of the leak. Make sure dishwasher is disconnected from mains power before attempting to work in it.
Apr 25, 2014 | Electrolux Dishwashers
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Electrolux dishwasher eidw6105gs1 No power and no
Hello Pamela, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, and faulty power supply or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 03, 2013 | Electrolux EWDW6505GS Fully Integrated...
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher model #EIDW6105GS1 My dishwasher was installed one and a half years ago and has worked beautifully and quietly until recently. The last three times I have washed dishes I hear the...
turn water off....remove the dishwasher....load it into the back of your pickup truck...take it to the recyclers....go to town and buy a different unit....NOT THIS ONE...this machine will never get any better...the only good thing about it is that it looks nice.....
Aug 29, 2011 | Electrolux Dishwashers
Our dishwasher model eidw6105gs1 will not start. You push the start and nothing happens. The lights are steady.
Think you need to reset it, leave it turned on overnight and door shut firmly, sometimes the problem is programme can not be finished from before.
Dec 01, 2010 | Electrolux EIDW6105GB 24 in Builtin...
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Electrolux EIDW6105GB 24 in Builtin Dishwasher Logo
980 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
