Question about Apple iMac G5 Desktop
Imac G5 harddrive replacement
Hello I am fixing an Imac G5 for a friend. When the Imac boots it comes to a gray screen with a flashing folder that has a question mark in the middle of it. This usually indicates that there is a missing system file, so I figured the only proper way to solve this was by reinstalling the OS. However, during that process I came to the destination selection screen. No hard drive was present.
My friend mentioned to me that the computer was dropped off the back of a delivery truck and was just given to him. So to insure that there wasn't any hardware failure I ran a diagnostics using Techtools Pro 4. Everything came out fine except it wasn't able to find a hard drive to do a volume check. I opened up the computer to check if there was even a hard drive mounted. There was a Seagate Sata in it. To be honest I don't work with Sata often because I am used to working with Ms-Dos based motherboards and they more the often use an ATA hard drive.
This hard drive didn't appear to have a power cable connected to it that you would see coming off of a power supply in a PC. Instead it had much smaller four pinned ribbon cable connecting from the motherboard to the side of the hard drive. I am not used to seeing this so I am just assuming that this is the power connector. After all of this I have concluded that the hard drive likely broke when it fell out of the truck.
If you have anymore insight on this problem it would be appreciated. I would also like to know where I can find an affordable hard drive for this computer.
Thank You,
Dr. Crowell
  • 108 Answers
I think you r right,
please get the same checked by an Apple technician
Posted on Jul 01, 2008
How boot up iMac - no bootable device - insert boot disk and press any key
Need more info EG It no longer comes on to boot up screen or it boots up to a gray screen or empty folder or it literally does nothing no sound or anything?
Sep 08, 2014 | Apple iMac Computers & Internet
I have a gray bar on the left side of my screen on my desk top that I cannot remove to get a full screen. Help.
Hello. That problem can be hardware, such as a faulty mother board (the video card is part of the mother board on the iMacs). This also depends ont the iMac model that you have. If it is a G5, there was a series problem with condensers on the motherboard, but it is now too late to claim a replacement. If it is a newer iMac with intel chip, I would advise to bring the Mac to an AppleStore near your place or a repair shop for a complete diagnostic.
I think that on an iMac, this kind of problem can't be software related, because it is an all-in-one desktop with no separated screen settings.
Hope that helps
Nov 09, 2013 | Apple iMac 17" Desktop
G5 Troubleshooting error 52
A couple of cheap fixes. Worth a try. If it boots, go to disc utility in the utilities folder and restore disc permissions. Then run repair disc. If that fails, buy a copy of Disc Warrior and start from that disc.
Apr 30, 2013 | Apple iMac G5 Desktop
Apple iMac g5 mac desktop stuck on white screen with apple no circle
Try two or three times, make sure there are no add ons usb
Mar 23, 2012 | Apple iMac G5 Desktop
I left my iMac quad core off for a few days while I was out of town, I came back and when I try to turn it on it goes to a gray screen, and a file icon appears with a question mark in it. I assume its a...
Try booting from your OSX cd, put it in and hold down "C" as it is booting up. If you can boot from the CD then you might be able to repair the disk using the **** utility in it or worst-case, re-install OSX.
It could possibly be a faulty connection inside the computer too.
You may need to take it in for repairs if you want to try and save the files (before reinstalling or opening up the computer!).
Hope this helps!
Jul 05, 2011 | Apple iMac G5 Desktop
I have an iMac G5, system 10.4, that gives me a white screen with the apple logo and lots of fan noise when I try to boot up. What's going on?
It is having difficulty with the system folder, try starting with the left hand shift key held down, if not boot from CD, select language as if you are going to do an install, on the next screen the top menu has a utilities folder, in this select disc utlility, select your hard drive and then select repair, let this work and if OK or repaired (if it says it cannot repair then you need a repair utlity like DiskWarrior) then repair permissions, this can take a while with a big HD, then in utilities select start up disk and select your HD and restart.
Dec 13, 2010 | Apple iMac G5 Desktop
Imac G5 will not boot up.
When you boot up g5 hold down the command button (apple logo) and the letter s at the same time to but the g5 in single user mode. When it boot in single user mode type fsck -f so it can check disk on the hard drive and repair Mac OS X. After it done doing check disk type exit and see if it will boot up regularly.
Mar 09, 2017 | Apple iMac G5 Desktop
Hello, I have an X800XT Mac Edition graphics card with a G5 2.0 dual processor and the problem I'm having is that when I boot up my G5, it goes through the spinning weel process, but when it's finished and...
I am going to recommend a hardware approach first and then a software approach, to this issue, in order to assist you. At the end of these procedures, is a general support link from Apple for additional support for no picture in your iMac G5 display
I am seeing more of such display issues like this, and more often than not, if the problem does not have to do with the firmware, it may be a damaged or corrupted file which can hinder the iMac G5 from normal start up functionality.
PMU Reset (try this first)
The PMU (Power Management Unit) is a micro controller chip on the logic board that controls all power functions for your Mac.
• Shut down the computer.
• Unplug the computer's power cord.
• Press and hold the power button for 20 seconds.
• Release the power button.
• Attach the computers power cable.
• Press the power button to turn on the computer.
* Boot to your desktop.
This procedure may help but if it does not, follow the procedure below
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
One of these two procedures should help resolve the blank display issue you are experiencing,
Additional Support Link:
Apple Support iMac G5 - No picture on display
Regards,
-Mactechtrainer
Dec 11, 2009 | ATI Radeon X800 XT Mac Edition AGP Video...
Can,t get imac G5 W Tiger to Boot all the way to desktop.Turns on,I get,Taa Daa sound,then just folder w flashing question mark.?How do I access Bios?
Hi, You need a Tiger or Leopard installation disk. Then You start up the system holding down "C" instead of installing you start the "disk utillity" and repair it.
You can access singel user mode by starting up the system holding down command + S.
/Per
Mar 23, 2009 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
376 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
