Question about LG 16x Internal Blu-ray Disc/ HD DVD Double-Layer DVD RW/CD-RW Drive
Yesterday afternoon I was using my computer and all of a sudden the lights went off. When it came back, my CD/DVD drive was not working anymore. I tried putting in different cds and dvds, but the light indicator blinks a few times and then stops.
  • LG Master
  • 27,725 Answers
It might be a power problem make sure the leads that are attached to your cd/dvd drive have secure connections and are not bad/faulty including electrical extensions or replace them they might be bad/faulty or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Nov 11, 2010
Now this is on my dad's desktop computer. (Acer aspire m1201) yesterday the disk drive was working fine iv'e just tried to use it this afternoon and for some reason it's not reading any...
If this is a floppy disk then run a disk cleaner and then try to read disk. If it is a CD or DVD om Drive then buy a good CD/DVD cleaner disc and run it on your computer.
Aug 09, 2011 | Computers & Internet
Acoustic Solutions TV/DVD P1480 has stopped working
Doh me, daughter had accidently hit the standby button without realising, had a brainwave after posting above and tried that, everything working fine.
Oct 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Computer won't detect Slave & DVD Drive
In the Bios Make sure you have slave and master enabled and be sure not to plug two hardrives into the same IDE Port
Apr 03, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Drive non responsive
Hi, it sounds like a bad CD/DVD. The DVD drive has a small hole in the front that you can use a small paper clip or tool that has a small tip and insert it into the hole and it will eject the DVD drive drawer then you can try another DVD or CD. Make sure the DVD or CD is clean and there is no scratches on it. You can clean the DVD or CD with a soft clean cloth and even buff out small scratches. Hope that helped.
Dec 14, 2017 | Fujitsu Siemens SCALEO C772 17" CRT...
My New Gateway isn't recognizing the cd/dvd drive :(
Appreciate the direct "Ask Me".
To your concern, two possible ways to correct:
  • download and merge cdgon.reg and EditReg from here. It is a zipped file, extract and read instruction in the READ ME FIRST.txt; or
  • manually edit the registry. Open "Regedit", go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and delete the entries "UpperFilters" and "LowerFilters"; Exit and reboot.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 18, 2008 | Computers & Internet
Cd Drive Doesn't work anymore.
Okay. Restart your computer and after, go to device manager (right-click on My Computer/Properties/Material/Device manager). Do you see a CD-Rom/DVD drive?
Sep 01, 2008 | Computers & Internet
CD/DVD Drive stopped working
try restoring ur computer few days back using system restore...
steps to do the same rae available on this link
http://www.windowsxphome.windowsreinstall.com/howto/lauchsystemrestore.htm
Apr 18, 2008 | HP Compaq Presario V6000T Notebook
Read only cd-r not dvd
Have the same problem, it used to work and suddenly it wont do it anymore. I guess this is due to windows XP updates. Windows says that the driver is up to date and I also installed the latest firmware. I am using Nero 7 to burn. I had troubles before but somehow fixed it. Now when I insert a DVD (data) and try to open the dvd drive the whole computer hangs. The content shows for a moment before the computer freezes so it IS in the DVD.
Oct 13, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
Drive doesn't read DVD's, only CD's
ur dvd device lens is not working properly.......so that it only read cd-----
if u r drive is in warrenty....then replase it.....or go to any computer hardware shop may be they solve u r problem.......
best regards & best of luck..
Oct 01, 2007 | Samsung SD 616E (729507925578) Internal...
LG 16x Internal Blu-ray Disc/ HD DVD Double-Layer DVD RW/CD-RW Drive Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
