Question about Oster ODF510 3-Pound Deep Fryer
Where can I find the ac power cord for the odf-510
Water leaking passenger side Hummer H2 from AC
The AC drain line is stopped up. Open the hood and you should see a small rubber hose/tube sticking out odf the firewall. Try running a pencil or other small object through it to clear the clog. If this doesn't work, go by a service station and have them clean it with compressed air.
Jul 17, 2014 | Heating & Cooling
HP 510 laptop respond to boot but was unable to display of
hello
take an ordinary CRT monitor screen (desktop type) and plug the 9 pin VGA into the notebook, of course plug the power cord of the CRT screen into AC outlet). Allow the system to boot up into normal sequence mode. You should get an output view on the CRT and If that's the case, then we can safely assume your notebook screen is not functioning and therefore the laptop screen has to be replaced. If the CRT output is not showing anything , then we can say that the LCD (from laptop) inverter may have to be replaced.
disconnect the CRT monitor
also, try this : place the CD recovery into CDROM bay and reboot the notebook system. While it reboots it willa sk you if you wish to boot from CD, press enter and let th sequence get to the install OS . Say yes and select the REPAIR System and allow this to take its course . Perhaps you have a corrupted OS . You may have to repeat this until the system can boot normally.
kind regards
Jan 02, 2012 | HP 510 Notebook
Hum
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversable, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
If it still does it with no cables or anything external attached it's an internal problem.
Dec 31, 2010 | Harman Kardon AVR 510 Receiver
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Hi there, I have just moved house and when I went to plug my HP 510 desktop back in there was no power. When I plug the main cord in the back the green LED flashes on and straight off again. Can anyone...
Are you sure that particular socket has power or is controlled by a wall switch? Sounds silly but I have had quite a few like that with a desktop. Take the battery out of the laptop, remove the AC adapter and push the power button in for 30 seconds to bleed off any residual power. Now plug in the AC adapter only and try to reboot.
Jan 18, 2010 | Computers & Internet
I have a cannon pixma ip1600 printer(photo),i lost the power cord, need to find one my email is babe12065@yahoo.com
The power cord is a standard ,common cord. Your local computer parts /office supply should have one esp. in medium to large cities.
Here is one on eBay:
http://cgi.ebay.com/Canon-PIXMA-Power-Cord-MP-460-470-800-830-510-530-600_W0QQitemZ230294722962QQcmdZViewItem
I usually shop @ Cyberguys.com: link for power cord. give them a call and they will help you find the right cable.
http://www.cyberguys.com/Templates/SearchAll.asp?search=power+cord&curpage=1&rows=ALL
Please remember to rate all users who assist you for free :)
Oct 04, 2008 | Canon Office Equipment & Supplies
Where to buy Power Supply for Xerox Documate 510
part number 70- 0497-100, you can buy this around 50$ , visit www.superwharehouse.com and provide this part number...
cheers dont forget to mark this pls
Sep 04, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Battery charge
Simply plug the included power cord into the power input on the DVD player. Leave the unit "off". Allow to build a charge. The included power supply items are:
Flexible power supply: up to 2.5 hours rechargeable Li-ion battery,
12volt car cigarette lighter adapter and AC/DC power adapter
Jan 08, 2008 | Mustek PL-510 Portable DVD Player
Oster ODF510 3-Pound Deep Fryer Logo
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
