Question about Toshiba Computers & Internet
When I turned on my computer this morning it said "cannot find operating system" Further checking it had "F3E1000001 PXE - E61 Media Test failure check cable; PXE -M0F Exiting Intel Boot Aget and then "hardrive not found." HELP?
  • Anonymous Mar 16, 2014
    1962 no operating system found
  • 3,940 Answers
You hard drive is not being detected by the BIOS. The PCE-E61 is the attempt to boot from the network connection (Known as Pixie boot) and is a tool used in large networks.
Ensure your hard drive cables are properly connected/seated.
If reseating the cables doesn't change anything, try resetting the BIOS defaults, and see if the hard drive is detected.
If all the above fail, it is likely you have a hard drive failure.
Posted on Jun 17, 2008
  • 91 Answers
What probably happened was that you deleted files that were vital for windows to run. What I suggest you to do is to perform a system recovery.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!!!
If you need further clarification please wire back and I would be glad to show you the necessary steps!!!
Have a good day!
Upon start up my Dell Mini keeps showing a code stating " intel UNDI. PXE.2.1 ( BUILD082) For Realtek RTL8101E/8102E PCI Ethernet controller v1.08(080408) PXE-E61: Media test faliure. check...
You computer is trying to boot from the LAN port (Ethernet).
Go into the BIOS by pressing either the F2 or the Del key. Check and make sure the hard drive is recognised by the system as with it saying "Operating system not found" does not sound good and could mean a hardware failure.
If it is seen by the BIOS check the boot order, change it to the HDD as the first boot device.
Regards.
Dec 15, 2010 | Dell Inspiron Mini 10 Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
When I turn it on, it makes a continuous sound for aprox 30 secs, then shows "PXE-E61 Media test failure". When working, it self-fills any empty fields with "n", not allowing any wrting...
Dec 04, 2010 | Toshiba Satellite L505-S5966 Notebook
Keep getting the following message when I turn on my Acer Aspire 5050 laptop: PXE-E61: Media test faulire, check cable PXE-M0F: Exiting PXE ROM Operating System not found
PXE bootup means the computer does not boot up from an operating system installed on a hard disk drive. PXE bootup uses a server on a network to boot up the computer.
It will not start without being connected the network that it was programmed to run on
Nov 16, 2009 | Acer Aspire 5050-3242 Notebook
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Nov 04, 2009 | Acer Aspire 5630 Notebook
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Oct 10, 2006 | Compaq Evo Notebook N200 Notebook
Computers & Internet Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
