Question about Jl Audio 12W7 Car Subwoofer
What way should I hook 2 12" jl audio to a jl audio 1000/1
    Sniper:
  • 58 Answers
Is this sub an svc or a dvc? From what I looked up they are svc, so each sub's voicecoil is 3 OHMS, connecting them in parallel would lower them to 1.5, and your amp is capable of going down to 1.5 ohms. So I would suggest running them in parallel.
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono What way should I hook - 2_4ohm_svc_2ohm.gif
(Although from the information I gathered these subs have 3 OHM voicecoils, so in the diagram where is says 4 OHM it should say 3 OHM, and the 2 OHM should say 1.5 OHMS.
This is a good site to help calculate OHMS: http://www.bcae1.com/spkrmlti.htm
Hope this helps.
Posted on Nov 11, 2010
  • Jamie Henning Nov 11, 2010
    Didn't realize the picture wouldn't work but clicking where the image should be should link you to the site, and if not I'll post the link...
    http://www.bcae1.com/spkrmlti.htm You'll probably have to copy and paste, you will want to look at option 1. Sorry for my mistake, but I hope I helped instead of causing confusion. If you need anything else I would be happy to help.
How do i hook up an amp to my sync sysytem?
Go to jL audio web link. Thayer have a sound processer that I used in my 2013 ford f150. I have two jl amps 1000-2v and a 500-4v. In the front doors are 6.1/2 jl comp and in back doors are 6-8 jl full range. And two 13" jlpancakes. I use a jl cross over. Hope this helps.
Jun 21, 2014 | Hifonics Car Audio & Video
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Low voltage light on
is not gettin enough power
low volt light on
Jun 01, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 problems
Hello l_miller36,
Depending on how much you paid for the amp on eBay, and how well you like the JL product, it may very well be worth the money to get it fixed. As for the wallet damage, you'll have to ask JL or one of their dealers. But, since the Slash2's routinely sell for over $1,000, I'd estimate the cost to be pretty high.
First, I'd send an email to JL Audio tech support and see if they have a "flat-rate" repair option or if they can give you an estimate of the repair costs. My second option would be to talk to a local car audio shop that does component level repairs. In the first case, you'd get exact replacement parts and whatever warranty JL gives on repairs. Not so with the local option, but it would most likely be less expensive.
Hope this helps, good luck.
May 31, 2009 | Jl Audio 1000/1 Car Audio Amplifier
JL Audio 1000/1 hook up to alpine type x
it is all up to the user, you can start by turning the input up slightly, I would not go over halfway because it usually starts to distort, then the bass boost up till they distort a little then back down a quarter turn.
Mar 10, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Input sensitivity
Make sure your multimeter is set for AC voltage.
Feb 20, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL audio hook up problems!!??
your w7 13's are dual 1.5 Ohm, but according to JL website, are 2.41 Ohms when the coils are in series. Each 13 connceted to each amp with voice coils in series is your best bet. The amps are designed to put out the same amount of power from 1.5 to 4 Ohms. If you parallel the voice coils, you end up with .6 Ohms and the amp will go into protect mode. You'll be drawing a lot of current, so you may want to think about 1/0 guage power wire, upgrade the wire from the alternator to battery (usually only 8 guage) and think about multiple batteries.
Feb 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Amp problem
you either have a bad ground or your power line is too small, the farther you go from the battery the larger wire you need.
Dec 18, 2007 | Jl Audio 1000/1 Car Audio Amplifier
JL 1000/1 Amplifier
mine did that. i cleand the battery wires and hook ups now it works fine.
Jul 24, 2007 | Jl Audio JL1000 / 1 Car Audio Amplifier
Jl Audio 12W7 Car Subwoofer Logo
170 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
