Magic Chef CDB1500AW 24 in Builtin Dishwasher Logo
Posted on Nov 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bottom sprayer not turning - Magic Chef CDB1500AW 24 in Builtin Dishwasher
Anonymous
Level 3:
  • Magic Chef Master 43,501 Answers
  • Posted on Nov 12, 2010
Anonymous
Magic Chef Master
Level 3:
Answers
43501
Questions
0
Helped
10834986
Points
101584
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Hello I am having problems with my dishwasher. Model BFDWC60ss. The detergent compartment doesnt doesnt empty after each wash so the dishes are still dirty after a heavy cycle. I have checked the...
Mary, have you checked the sprayer holes being plugged up with gunk. Remove the lower rack and inspect the spinner/sprayer holes turn by hand and notice if there is anything rattling around in the sprayer. I am not familiar with how the sprayer wand is attached on that unit but alot have a plastic nut you can turn to get it off and clean it thru the bottom water input hole. Or a cap with a screw under it.
Hope this helps.
feel free to let me know if you need more assistance.
Happy New Year
Jan 01, 2018 • Dishwashers
1helpful
4answers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
1helpful
Dishwasher not pumping water to turn sprayers
either your sprayers are clogged or your water solenoid valve is stuck or defective also could be loss of line voltage to the solenoid
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 • Dishwashers
2helpful
2answers
Water is slowly dripping from the bottom of the sprayer and subsequently runs down the hose, puddles near the sprayer base/countertop and eventually drips onto the plywood under the sink. I would think...
I have never replaced the parts in a sprayer .In the book that I usually order from they only sell the compleat spayer.Im not saying that they dont make kits for them. but I havent seen them, Untill you can get you another sprayer unscrew the sprayer from the hose on the bottom there is a flat washer flip it around.that should work for a while.
Kitchen sink sprayer leaking. Tried to install a new sprayer; but turn off knobs are seized and could not budge. Turned water supply to whole house off, but still cannot remove the old sprayer. These are...
First porblems first; go to Home Depot and pick up two Gator Bite valves (no pipe sweating...work great!), appropriately sized and replace hot/cold water valves under the sink. It would also be best to get 1/4 turn valves instead of a gate valve.
The spray hose is connected at the base of the faucet itself - in the very center of the bottom side of the faucet. It's a very tight and difficult area to work in - you should be able to usscrew the old hose and place the new one directly where the old one was removed.
HTH,
Mike...
Nov 25, 2009 • Hammering
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Bosch sprayer arm found in bottom of dishwasher
how many pieces is the sprayer arm and how many sprayer arms to do you have 2 or 3?
Top Magic Chef Dishwashers Experts
Dave Yale
Dave Yale
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
