Question about Texas Instruments TI-Nspire Graphic Calculator
My calculator slipped off of my bed and onto hard wood. I'm concerned that it is broken. I switched batteries but it won't turn on. Any suggestions?
    Problem Solver:
  • 12 Answers
Why won't my battery charge? Charger is good. Was charging and my tablet fell off the bed onto the floor.
Sounds like you have broken the charging port. I would suggest you take the tablet to an authorized repair center to have it repaired
May 02, 2016 | Tablets & eReaders
How do I trouble shoot an engine that won't start?
Hi, Frank and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping. Good luck and have nice a day.
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
What to do When Your Motorcycle Won Start
Troubleshooting No Start Honda Motorcycle
Motorcycle Won Turn On Solved
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 06, 2016 | Motorcycles
What type of frame should I buy for my sofa bed?
You can buy sofa beds with wood or metal frames. The metal ones tend to be less comfortable for sitting against when it's back in sofa mode. Go for a hard strong wood if you want something that will endure. Avoid soft woods such as pine frames.
Sep 10, 2012 | Furniture
Calculator won't turn on after battery leak
Having gone over a month without a reply to my query, I assume one or another of my suggestions solved the problem.
Oct 17, 2011 | Texas Instruments TI-84 Plus Calculator
Broken Paper Roll Holder
You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
Dec 07, 2009 | Victor 1430-3 Calculator
The grill / top oven knob will not operate the grill any suggestions?
It is possible the knob is slipping round and not turning the spindle of the switch, or the spindle is broken inside the switch, or the switch is partially seized up.
Pull the kjnob off the switch, and try turning it on wioth pair of pliers or grips, if that works, then the switch is probably o/k.
Also spray some WD40 onto the switch spindle, and inside the switch.
Please leave feedback.
Thanks.
Nov 13, 2009 | Ovens
TRying to change into full size bed with no instructions do i need special rails or standard ones?
The fourth stage is where the bed can be turned into a full size bed. The "front side" and the "back side" are turned into the headboard and footboard. However, at this point a steel full-size bed frame would need to be bought (from any mattress store) to turn it into a full-size bed. You used to be able to get matching wood side rails from Simplicity but since they went out of business you can't. you could have them made if you found matching wood or stain from lowes. not that hard. that's what we did.
May 31, 2009 | Simplicity for Children Prescott 4-in-1...
Texas Instruments TI-Nspire Graphic Calculator Logo
47 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
