Question about Brother ML-100 Typewriter
I have a Brother ML 100 Standard I changed the ribbon on it and now I can't get english language to type on it. Please help
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Press CODE and KB II or KB III and the corresponding number of KBII is number 2. So you have to Press CODE and 2 together.
Posted on Feb 19, 2015
  • Brother Master
  • 3,594 Answers
Check to be sure the ribbon or L/O tape aren't tangeled in the P/W, check the P/W for bent spokes.
DickyO
Posted on Nov 12, 2010
My ink cartridge is not seated in brother ML 100 typewriter when replaced
ML 100 takes a ribbon that should snap iin place.. front toward you first then back drops down....
Oct 02, 2014 | Brother ML-100 Typewriter
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
When typing, the letters are not showing up well unless it is on double strike. have take printwheel out and changed ribbon but still not striking paper well.
The problem may be the ribbon or the media you are typing on. try typing on a mulit part form, if the copies are good then its the ribbon (OLD) or the paper (GLOSSY).
DickyO
May 06, 2011 | Brother ML-100 Typewriter
Just installed new ribbon cartridge and still cannot get anything typed. worked fine three days ago.
If it worked befor you installed the ribbon then check the installation or if the ribbon is very old it may be bad. Try typing on a multipart form and see if the carbons print.
Go to brother.com, click on support, poke around a bit and you will find a downloadable users manual.
DickyO
Jun 29, 2010 | Brother ML-100 Typewriter
How do i change the font type and size on a "brother ml 100" type writter?
To change the type style or size replace the printwheel and adjust the pitch.
Go to brother.com click on support you will find a manual there with pictures.
DickyO
Mar 29, 2010 | Brother ML-100 Typewriter
Brother ml 100 can't get it off the correction tape mode
First remove the correction tape, then turn it off and back on and let it do it's reset, if it will now type OK check to be sure you have a dry L/O tape, if it is at all tacky replace it with a dry L/O tape.
Jan 05, 2009 | Brother ML-100 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Ribbon problem
does the ribbon feed by hand? If not get a new ribbon.
DickyO
Dec 24, 2007 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
