Question about Panasonic DVD-RV31 DVD Player
DVD player will not read any disc
DVD-RV31 cannot read any dvd. When I turn on the power, the following happens. It says welcome to DVD world. The it says Read. Two "0"s appear to the left of the word "Read", then disappear. This happens four times. Then it says H02. That disappears and it says stop.
  • 8 more comments
  • Anonymous Jul 01, 2008
    Exactly the same here.
  • Anonymous Aug 13, 2008
  • dogandponyon Sep 18, 2008
    same problem
  • Anonymous Sep 24, 2008
    I just experienced the same problem.
    H02
  • H2OMAN41 Oct 05, 2008
    Same deal.
  • michelleprat Oct 11, 2008
    Same problem as previously posted - won't play DVD, tries to read, the HO2, and Stop.
  • Anonymous Oct 30, 2008
    Same problem. Started 4 years ago. Just got around to troubleshooting the problem.
  • rmross01 Dec 26, 2008
    I do have the same problem. What is the solution?
  • njkm Jan 01, 2009
  • swampyboggs9 Jan 02, 2009
    I have the same problem. It just started, like two weeks ago doing this. A shame. I have had this player since Jan 01.
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Posted on Feb 03, 2009
SAME PROBLEM EXACTLY
Posted on Aug 04, 2008
Upon inserting a dvd in the player, the player can't fully read the disc until the display reads "HO2".
Hi , Just simple ,
option 1:
Please open case and clean the lense
or
option 2:
use good lense cleaner cd with liquid.
just drop liquid on to cd cleaner ( excatly on brush)
then you run.
it will solve your problems.
Dec 01, 2010 | Panasonic DVD-RV31 DVD Player
Has power. When
It is due to the reading LED inside it, you just check whether it is working or not.
Jun 10, 2010 | Panasonic DVD-RV31 DVD Player
The Open/close does not work. Power is on and it
First try resetting the player. Unplug for 1/2 hour-1hr., press and hold power button for 3 seconds, wait 1/2 hour, plug back in and it should work. Otherwise you can pry open the door with a paper clip. Slowly pull door as far back as it will go, then press eject button and see if everything aligns itself back on track.
Nov 23, 2009 | Panasonic DVD-RV31 DVD Player
Panasonic DVD RV31 does not read DVDs created by Windows Movie Maker
The only thing that has worked for me is to make a copy of the disk after burning it in Movie maker.
Cordell
Jul 06, 2008 | Panasonic DVD-RV31 DVD Player
Region free code for dvd-rv31
all you need to do is use the DVD Service Disc that you got when you bought your DVD player,, or  go to www.panasonic.com and e-mail them about getting the codes removed so you can play overseas DVD, they sent me a disk for FREE and guess what it worked,,,, it comes with the instructions, here is what it says,,,
INSERT DISK- and confirm "STOP" is displayed...
USING THE REMOTE press "SETUP"
Go to "DISPLAY" menu
Select "ON SCREEN MESSAGES" then press "ENTER" button
Press ">10" found on the bottom right coner
Press "6" button
Press "4" button
Press "3" button
Press "8" button
A PASSWORD WINDOW SHOULD APPEAR
TYPE IN "3192"
PRESS THE "ENTER" BUTTON TWICE
the disk will be read, when finished remove disk
Oct 15, 2007 | Panasonic DVD-RV31 DVD Player
Panasonic DVD-RV31 DVD Player Logo
946 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
