Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Well I have a flashing green light on my xbox 360 wireless connector. and i can not connect to xbox live, i used to be able to. Any help?
    Sergeant:
  • 389 Answers
If you are interested we can research it further or you can try to reconfigure it in your Xbox settings.
Posted on Nov 12, 2010
  • Mohamed
    Mohamed Nov 11, 2013
    I am trying to disable the firewall and open ports on my router but i can't, because it's an old version so i can't find anything :\
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: my black wireless adaptor (xbox
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Jan 20, 2011
  • 60 Answers
SOURCE: Wireless Network Adapter Xbox 360 (SKWIFIX360): My xbox 360 wireless adapter won't stop flashing g...
Make that your wireless router is successfully configured to your network.
Posted on May 20, 2010
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
I can not seem to get onto the internet with my Wireless connector for the xbox live it is trying to get a signal but is not connecting can you help. The connecter is flashing at Green but just does not...
make sure that you run the dvd it came with, that is the most important, then go into your setting on the xbox and pick your router out of the list, the green light should stop flashing when it picks up your router, especially if you have a password on your router, you will need to enter that in the settings screen
Feb 28, 2010 | Microsoft Xbox 360 Wireless Controller
For my xbox i have a wireless connector and wireless interet in my house but the xbox wont connect to live
Will it not connect, like it gets to the point to connect and nothing or...? Also, check the actual wireless usb connector led light. Is it red or green? These things have a tendency to get shorts in them. Try wiggiling it around and see if the light flickers off and on.
Jan 31, 2010 | Microsoft Xbox 360 Console
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :)
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox live on netopia router
Okay so here we go!
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Jan 10, 2010 | Netopia 2247NWG-VGx Wireless Router...
Xbox 360 wireless guitar won't sync with console
seems like the sync problem with XBOX console, you can try fixing this with the help of XBOX 360 repair guide
available here
Jul 14, 2009 | Microsoft Guitar Hero: Aerosmith with...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
473 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
