Question about Nortel Meridian M7208 Corded Phone
I have a Meridian nt5b01 phone system with 8 handsets hooked up. when I try to add hookups for additional handsets the set I'm testing with will never quit blinking. Any clues what could be the problem? I bought the control unit used and was under the impression it was good for 16 phones. Is this my mistake?
I need to upgrade meridian NT5B01, is it possible to add voice mail or others, please give me the items that I can upgrade my system with insted of changing it
Posted on Jun 27, 2011
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
AT&T 2230 2.4 GHz Dual Handset Cordless Phone - additional phones?
Hi yes you can add additional phones to it as long as their the same frequency so that they pick up the signal from the main phone that plugs into the phone line.
Im sure you can have upto 4 handsets but just make sure theis same make and frequency
Jan 29, 2008 | AT&T 2230 2.4 GHz Dual Handset Cordless...
Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Nov 26, 2007 | NorStar Meridian M7310 Phone
HOW CAN I TURN UP THE VOLUME ON HANDSET. VOLUME IS SO LOW CALLERS CAN NO HEAR ME
There is no outgoing (microphone) volume control, if it is only your set try the handset from different extension. The microphone element may have been damaged (especially if dropped) and have to be replaced. Replacement handsets are not hard to find. If everyone on your system claims that callers cannot hear them, there are some settings on the central switch (KSU) which might help, but only after ruling out a problem on your particular set.
Jun 16, 2014 | Nortel Meridian M7208 Corded Phone
How can I add a handset
You can add a handset by purchasing an additional one that matches your system. The additional handsets come with a cradle, a power cord and the phone itself. All you have to do is charge it for 24 hours and then plug it in and it will automatically work with your main line.
Jul 12, 2011 | Uniden 2.4 GHz Cordless Phone System
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Handset test on meridian norstar M7310 / M7208 / M7100
Feature 805 is valid on versions 2.0 or above.
Jul 07, 2010 | NorStar M7310 Phone
No dial tone
It sounds like you have the wires hooked up wrong. Check both ends of the wire.
Jun 01, 2009 | Nortel Meridian M7208 Corded Phone
MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Dec 09, 2008 | Polycom SoundPoint Pro SE-225 Corded Phone
Line programming
That is a feature under system programming for your set. your admin person would need to make that change fir your extension.
Dec 01, 2008 | NorStar Meridian M7310 Phone
Nortel Meridian M7208 Corded Phone Logo
217 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
