Question about Eiki LC X986 Multimedia Projector
Eiki LC-X986 - How do I get to the filter to clean them
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
At the side of the carrying handle you can pull out two grey plastic frames, these are the air filters, If just dry dust, clean with air or vacuum cleaner. If smoke/ oil clean with alcohol and put them back.
This model has no filter hours counter, so no need to reset
Posted on Apr 17, 2014
4 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
heathgr
  • 442 Answers
SOURCE: My church has an EIKI
Have a close look at the fan and check if there is a make and model number on it.
If you cant see anything, unscrew the fan and check on the hidden sides.
see what voltage it is. ie 12v dc or 24v dc
Ring the EIKI agent and ask them how much for a replacement rear fan, the EIKI part number, and also if they can supply the manufacturer of it and their part number.
Check that the fan connector is OK, and the socket where it plugs in.
Check that the fan turns freely.
report back what you find
Posted on Mar 24, 2011
Convergence
LCD panels are broken. you need a new one
unit price is USD120
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 01, 2013 | Eiki LC-X986 Projector
Double image in horizontal direction, even on menu items.
have a nice day!
When I connect projector to computer the computer monitor turns black
to change the setting on your computer
any questions, feel free to contact me
have a nice day!
Sep 06, 2013 | Eiki LC X986 Multimedia Projector
My church has an EIKI LC-X986 projector that turns on for about 2 seconds then shuts down. The lamp is brand new and the filters are clean. I know the signal is working as I can see it for those 2...
Mar 24, 2011 | Eiki LC-X986 Projector
How can you view the amount of bulb hours for an Eiki LC-986?
The manual for your projector is found here:
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_x986.pdf
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to
move a red frame pointer to SETTING Menu icon (refer to page 37).
Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
Mar 03, 2011 | Eiki LC X986 Multimedia Projector
Squiggly line down right side of screen. cuts off part of word had red line sometimes
I would send to a projector repair services to get a free diagnosis. I got my projector checked at TP matrix projector repairs- the number is 0161 626 4067. They sorted the colour disfigurations out on my projector really quickly and cheaper than most other service providers i found. it was a sanyo projector- but they said they can fix any make.
Sonmetimes projectors just need the optical prism cleaned out. TP did a really good job on mine.
good luck
Mar 01, 2011 | Eiki LC-X986 Projector
I have the Eike LC-X986 projector and it keeps turning off every 20 minutes. Can't figure out what's wrong. Please help.
if the time is always about the same, then blocked air filters should be cleaned. if there is no sufficient air inflow, temperature inside will become above maximum rating and PJ will shut down.
Dec 22, 2010 | Eiki LC X986 Multimedia Projector
No functions
No led ? Check primary powersupply circuits for dried out ( smd) capacitors.
Nov 08, 2010 | Eiki LC X986 Multimedia Projector
Unit cuts off on high heat after bulb was replaced. All fans are working and filters are clean.
clean out the rest of the projector with canned air. make sure there is nothing around the vents.
Oct 09, 2009 | Eiki LC X986 Multimedia Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Eiki LC X986 Multimedia Projector Logo
82 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
