Question about Dell Latitude D600 Notebook
DELL D600NFULLY CHARGED WHEN ON BUTTEN PRESSED NO ACTIVITY
WHEN ON BUTTON ON TOP IS PRESSED ON D600 LAPTOP THERE ARE THREE ICONS BETWEEN START BUTTON AND MUTE BUTTON. THE MIDDLE ICON FLASHES SEVERAL TIMES THEN NOTHING. NO ACTIVITY IN THE SCREEN. ALSO THE MIDDLE ICON LOOKS LIKE A SQARE PAD LOCK WITH AN 'A' INSIDE THE SQARE.
  • ablev Jun 17, 2008
    I have no problem with paying the 15.00 if you can tell me how to fix the problem. i just am uneasy giving my credit dcard info when i don't have the agreement of non satisfactory performance upfront in writing.
  • 3,940 Answers
The Caps Lock LED flashing indicates a Motherboard failure on the system
Posted on Jun 17, 2008
My computer is not working there are no icons on the bottom of the screen and the icons for internet doesnt work and the other icons doesnt work
I also have a Dell the same problem occured twice, I called the techs and had to have a mal ware virus removed both times!!! They had me switch off the computer and tap f 8 multiple times and the remote accessed my computer......hope this helps!!!
Jul 19, 2012 | Dell Latitude D600 Notebook PC
My dell D600 laptop fails to boot, when i press the power button the three indicator light on it will on for 3 seconds and will off.
Try flexing the whole bottom assembly. that is with the laptop open put your knee in the middle and grab the unit with one hand on the corner closest to you and the other near the screen and put enough pressure to "flex " the mobo right after you push the start button if it doesn't start try it the other way... this has been working for my grandsons d600 for 6 months. i tried a new switch board because the guy that sold me the mobo said the plug for that is know to crack. good luck ps you will know it has worked when the 3 lock lights go out and the power light stays on.
May 12, 2011 | Dell Latitude D600 Notebook
My dell d600 latitude laptop indicates a lock button in the top icons and cant procede from there
purple function key next to the ctrl key
press that down and hold
press the num lock (toggle)
press the scroll lk (toggle)
press white cap lock only
See if any of these change the lighted lock indicator.
I assume that was what you mentioned in a focus of the request
Aug 19, 2010 | Dell Latitude D600 Notebook
When i pressed the power button, the notebook didn't turned on.
Assuming that the laptop either had the battery fully charged, or the power plug is supplying the power.
The issue may be the power button. I have had some break. It is very interesting how flimsy some of those buttons are attached.
If you can remove the top bezel that covers the power button you may get a better look.
The power can be actuated by a small button not much bigger than a pin.
Good luck
-Carlos:
Jan 06, 2010 | Dell Latitude D600 Notebook
What do the activity lights on the keyboard of the Dell Laptop C640 represent?
To the right of the power button and below the Dell AccessDirect button are three lights. These have a lock synbol below them. The first one from left to right is signified by a number 9, this light is turned on when the numberical keypad is enables. The center light is signified by a letter A, it is on when the uppercase letter function (Caps Lock) is enabled. the third one, far right, signified by a down arrow, is on when the scroll lock function is enabled.
The device status lights on the far right side near the front of the laptop case. The top light is the power status light, the middle light is the Hard drive activity light, the bottom light is the status light for power management, battery, AC etc.
Oct 17, 2009 | Dell Latitude C640 Notebook
NO POWER-UP ON C600
That's either a fried processor (hope not!) or a flat CMOS battery. It's a nightmare to get at that battery - you'll need to open the case completely and get at the motherboard. Once you've done that though it's easy enough to replace it, although you may need to do some shopping on ebay if it isn't the standard CR2032 coin cell type.
Hope that helps,
Matt
Aug 25, 2009 | Dell Latitude D600 Notebook
I have a dell d600 and the power light comes on for about 3 secs. then goes out and nothing happens... help...
This is common issue and that typically means your Processor is dead. If you dont hear any beeping and it powers off after three seconds without any activity on the screen means BIOS hasnt even found the Processor and without the processor you will get no POST. Post is a bunch of tests for hardware components and give beep codes if it finds an error. Only issue it cant post an error if the processor isnt working. Solution, order a new processor for your laptop and replace it or buy a new computer. If you order a new processor be sure to order some thermal paste too.
Thanks,
ArmyMason
Feb 25, 2009 | Dell Latitude D600 Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Dell latitude D600 booting problem
Are all three lights on when you hit the power button?
Aug 25, 2008 | Dell Latitude D600 Notebook
Dell D600 will not power on
I have one that does that periodically. Probably not the highest tech solution but I give the keyboard a robust slap just to the right of centre & this always does the trick. (Originally tried re-seating memory and CPU to no avail and in frustration gave it a slap & it worked!)
Aug 13, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
336 people viewed this question
Alun Cox
