Question about Whirlpool MH1150XMQ Microwave Oven
MH 1150xmq-1's turntable does not rotates - Whirlpool MH1150XMQ Microwave Oven
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 12, 2010
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Whirlpool Microwave Ovens
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Model # OGB81201 approx 1 month old. Microwave does not work turntable does not rotate, Convection and grilling apprear to work and turntable rotates when using these features. When i push the quick...
Approximately 1 month old? Should still be under warranty. Before doing anything else, contact the store where you purchased the oven and see if they'll exchange it as defective. If not, they may take the unit in for service there. Failing that, check your owner's manual to see what to do for service.
Feb 27, 2010 | Microwave Ovens
Turntable does not rotate when turned on.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If the cooling fan is good, but yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Jan 11, 2010 | Emerson Microwave Ovens
Turntable does not turn
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Jan 10, 2010 | Emerson Microwave Ovens
Help inside tray will not rotate
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Mar 01, 2009 | Microwave Ovens
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
My microwave oven makes a terrible noise when it rotates. 700W MW8871W/B
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Oct 24, 2008 | Emerson Microwave Ovens
Goldstar 1310W built in
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Aug 11, 2008 | Goldstar Microwave Ovens
Whirlpool MH1150XMQ Microwave Oven Logo
42 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
