Question about Zoom X6 Adsl Wireless Gateway Rohs Router
Hi how can i put a lock on my router. - Zoom X6 Adsl Wireless Gateway Rohs Router
I can't get the password on my dlink. i put in admin were it says password and i even tried putting password where password did,t work. tried resetting the router and that didn't work... i had this...
best solution is to reset the router to default settings:
In order to do that use a pen or paper clip to push the reset button for around 30 seconds.
Please download and refer to manual I linked below:
Manual
I hope this information helps.
May 11, 2011 | D-Link DIR-615 Wireless Router
Need someone to tell me how to put a lock on my router
You can enable wireless security on your wireless network by following the step by step procedure from my TIP.
Just click HERE then you can now begin the procedure to enable wireless security on your router.
May 09, 2011 | Linksys Wireless-G WRT54G Router
I'm trying to put a lock on my router
go to 192.168.0.1 on ur internet browser and go on wireless settings then go to security and apply lock
Nov 07, 2010 | NetGear DG834G Router
My daughter locked our router a belkin g wireless and forgot the password how do i fix it
Reset the router, push something into the reset hole on the back of the router for 20 seconds or so
Aug 15, 2010 | Belkin (F5D7230-4) Router (587009)
I have belkin n wireless router and the lock picture on moden is on, so i am not able to conect my wireless lop top, it says that the router is encrypted
hi you can reset it to its original settings by pressing in the reset button on the back , once reset just type admin = user name password = password then you should be able to put it back the way you want it...hope this helps
Mar 25, 2010 | Belkin Computers & Internet
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
Router won't lock
u have to reset your router check in back side of router 1 reset button press it for 5 second then it restert and reset.
Dec 29, 2008 | Belkin (F5D7230-4) Router (587009)
I am getting internet signal if I plug in the cord from the wireless router to the laptop. The laptop says we have signal and we are connected to our home network but then we cannot use the internet. It is...
You have set up some kind of security on your router, you have to do the same on your laptop.
Se it as a key that have to fit the lock in order to open the dor.
When you access the router, USE A CABLE, do NOT access the router with a wireless conection.
/Teis
Vote :-)
Nov 30, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Zoom X6 Adsl Wireless Gateway Rohs Router Logo
52 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
