Question about Kirby Ultimate G Bagged Upright Vacuum
Belt not locking
I just took apart the brush/roller and cleaned out. I am trying to put the head back on and make the beater bar roll and it will not. Are the green arrows supposed to be lined up when regular vacuuming? I tried that and it does not catch the belt--it only catches the belt when I line up the red arrows. I have a G3. Help
  • vacuhelp Jun 17, 2008
    Thanks, I was not leaving the red arrows aligned while placing the head back onto the vacuum, then moving it to the green arrows in line.
    President:
  • 1,673 Answers
With the nozzle off of the vac., turn the big knob on the front until it locks. (will only turn one direction) Put the nozzle back on the vac, lock it down, turn the knob again and the belt will be on the spindle and you should be set to go. I hope tho that you put on a new belt, they stretch after a short time and will start slipping under load.
Posted on Jun 17, 2008
My beater bar is not spinning on my Dyson DC39. Ive taken the head apart and see no reason why it wont spin. Any ideas
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 03, 2017 | Dyson Vacuums
This is a post from you concerning a Sebo vacuum cleaner."OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on...
First, what is the issue you are experiencing?
You should feel some resistance when turning the beater bar as it is being driven by a fairly tight belt and a motor. The most common issue with the beater bar would be a burning rubber smell. This would mean that the bar was not turning while is was on but in your case it is.
May 08, 2014 | Sebo X4 Bagged Upright Vacuum
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Jun 19, 2017 | Bissell 6594 PowerForce Bagless Upright...
The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Nov 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Bissell Vacuum brush stopped rolling
The belt may be broken. Consult the user manual or locate on the sole plate or front hood when getting to the sole plate. Usually it involves a few cross head screws on the base of the vacuum cleaner where the roller beater bar is. Remove that and check the belt. If its broken, carefully replace it with a new one and see if that works once everything else has been put back.
Mar 27, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Dirt Devil Featherlite - how to remove the beater bar to clean
If you lay it down and look under the base- by the brush roll- there are three screws you have to remove w/ a philips head screwdriver to get the base plate off. From there you can take out the brush roll, etc.
Mar 12, 2009 | Dirt Devil Featherlight Bagless Upright...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
180 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
