Question about Bulova Watch
How do you get a Nordam watch (Walmart) to begin running? This a new quartz watch but the instructions are missing.
No work quartz
This watch is kinetic, in that a moving rotor inside the watch powers a rechargeable battery that runs the quartz mechanism. You should not need to attempt to open the watch! It may be that the battery is flat (especially if it's not been worn for a while) - you can try swinging the watch back and forth to charge it (check online for charging instructions for Seiko or Pulsar kinetic watches). If that fails, take it to a reputable establishment for repair.
May 22, 2016 | Steinhausen Stahlhammer Dual Time...
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
I have a marykate and Ashley ladies quartz watch model number MKA0132PC21 and i cannot get the backing off to replace the battery. Nelsonic is listed as the manufacturer and i would like to know if you can...
It should spin off counter clock wise, usually need a special watch tool ? Not always tho, and most jewelry departments in Myers, Walmart, etc... will open for free if your buying a new battery, really hope this helps ?
Feb 23, 2015 | Watches
Hi, I found on a street market a MIYOTA T241 watch in original package, also a plastic shield on the glass. Now the problem: May be the liquid of the battery destroyed any power supply wires or contacts. I...
mcdevito75 here, Once the battery leaks it destroys the quartz mechanism. Even if you find a replacement quartz, you"d need special Jewelers tools to remove and replace the quartz, even with that you could destroy the new quartz if you can find one. Best Bet, see a small watch repair shop in your area for a quartz replacement approx. $75.00
Sep 29, 2010 | Watches
The light was fading on my Indiglo Timex watch but it was still keeping good time, so I had a new battery installed by a Walmart employee. The light now works on the watch but the watch stopped keeping...
mcdevito75 here, Your Timex watch is most likely an Indiglo meaning light, The battery supplies power to to Quatz mechanism for time keeping and for the light. There is a very good possibility that 1 or 2 of the contacts between the battery and the Quatrz mechanism were lost during the new battery installation. While you can"t rule out that the Quartz mechanism and or the light may be wearing down, you still have to suspect the battery even a new battery, look for a small watch repair shop in your area and try another battery, let the jewler know of your watches problem so he / she can properly install the battery and ensure the contacts between the Quartz and the battery are being made.
Jul 07, 2010 | Timex 27191 Wristwatch
I bought a new watch today and i cant get it to run
Watches fall into two basic categories - quartz and mechanical. If you bought a quartz watch that is battery powered you need to set the watch and push the crown in all the way to start the watch. Sometimes you need to remove a small plastic piece from the stem to push it in all the way. If you bought a mechanical watch, even if it is an automatic self-winding model, you will need to manually wind it to get it started. If you are still having problems take it back tot he dealer for a demonstration or to have the battery replaced if required. An instruction sheet and warranty card is packaged with almost all new watches. Sorry I can't be more specific but if you care to share the make and model number I may be able to help you further.
May 01, 2010 | Watches
Broken band
You can go to walmart and they sell bands and also try the flea mkt. They have all different brands that fits your style and even change the pins.
Nov 30, 2009 | Diesel 3 Hand Brown Digital Quartz Display...
Bulova Watch Logo
346 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
