Question about HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
The machine won't power up. The green light on the PS flashes. What does this mean? If I disconnect the large plug from the mother board the green light will come on steady. Plugging it into the mother board leaves the light on steady, but when I press the power button it tries to start and then goes into it's flashing mode.
  • HP Master
  • 27,725 Answers
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle and fail to boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Nov 11, 2010
    President:
  • 1,082 Answers
Can you tell if the flashing is a pattern. count the flashes ( long and short) in a cycle. This will provide an error code to hopefully discover the problem.
You may also try removing and reseating the RAM and Video card, blowing out the connectors with compressed air before reseating.. Also look closely at the components on MB for any signs of swelling, leaking, burning etc. I suspect the MB.
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
The purple light is flashing in the front and tries to start and won't turn on. disconnected power cord and held button in for thirty seconds still have same issue what could it be?
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Jun 21, 2009 | E-Machines T6216 (827103077834) PC Desktop
No power
This suggestion is a real long shot but at least it something you can try. It sounds like you've already ruled out all the other stuff I was going to suggest. Try replacing the CMOS battery on the mother board. It's one of those large flat batteries about the size of a nickel.
Jun 03, 2009 | Gateway 505GR PC Desktop
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
NO POWER
Heyy don't panic. I know its very costly to replace mother board or power supply SMPS. And i assures you that neither its mother board problem nor power problem. Its a problem with your RAM only. If RAM is faulty then laptop starts giving same problem.
So, please go & replace your RAM. Its not that must costly also. So you can easily afford also and new RAM will boost the performance of your laptop.
Rate this solution if it was helpful to you.
Apr 27, 2009 | Acer Aspire 3680 PC Notebook
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Feb 23, 2008 | Computers & Internet
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
POWER SUPPLIES HAVE AN INDICATOR LIGHT FOR A REASON.
REMBER - BLINKING LIGHT IS AN OVERLOAD OF THE PROTECTORS AND ELLIMINATING THE OVERLOAD SOLVES THE PROBLEM AND THAT THE POWER SUPPLY IS WORKING AND CONVERTING POWER.
NO LIGHT MEANS NO POWER OUTPUT AND THAT INDICATES THE POWER SUPPLY IS NOT FUNCTIONING AND NEEDS REPLACED.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Logo
180 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
