Question about Dryers
How do i change my dryers 4 prong cord to a 3 prong. It is a Maytag PERFORMA
  • 246 Answers
The procedure is the same for most dryers. Follow your old cord to where it goes inside your machine. Does it have a clamp around the area where it enters? If so remove the clamp. Right abover the hole where it enters, there should be a plate. Remove the plate and you should see 3 brass colored screws. Loosen the screws. Depending on your manufacturing of your dryer the 4th (green) wire will either be on top of the white one or be secured by a green screw on the cabinet. If it secured to the cabinet, loosen the crew, remove the green wire, and re-tighten the screw. Now your 3 wire cord should be gray (these are availible from more appliance parts stores and hardware stores around town). Feed this cord through the hole. The 3 wire cord is flat so putting the wires on wrong is more difficult. Just make sure the wires do not cross and the cord stays flat. Most replacement cords come with these instructions and pictures too.
Posted on Jun 21, 2008
Change maytag 4 prong dryer to 3 prong
UNPLUG dryer, the three pron cord just dosn\'t have the green ground wire that goes to the cabinet screw.
Remove 4 wire cord.replace with 3 wire cord, as long as you get the white wire on the middle screw you will be fine.
Aug 31, 2014 | Dryers
How to ground a MDE6700AYW dryer after changing to a 3 prong cord
Hi fievelsgal21...
Go to the following webpage and it will show you what and where to connect the ground wire when converting from 3 to 4 wire or 4 to 3 wire.
Please rate me
Sep 28, 2012 | Maytag Neptune MDE6700A Electric Dryer
Change Maytag dryer 4 prong plug to a 3 prong plug
The cover on the back should only be held on by screws and are usually easy to get off. Have you checked for these?
May 04, 2012 | Dryers
How do you change a 3 prong cord to 4 prong power cord on a maytag neptunre MDE4000ayw
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Change 3 prong cord to 4 prong cord on electric dryer
Feb 16, 2011 | Maytag Dryers
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Bought used dryer. Plugs don't match. Can cord be switched?
Yes, these cords can easily be switched. When you remove the three prong cord from the terminal block in the rear of the unit, you will wire the four prong in the same way. Black and red go to the outside terminals, white to the middle terminal, and the green wire goes to the cabinet or ground screw on the outside (usually, there is a greenish looking bolt around the terminal block door area for this to go). The only difference in a 3 and 4 prong configuration is the extra ground (green) wire. Good luck and let me know if you need further information.
Feb 01, 2008 | Maytag Performa PAV3200
Dryers Logo
70 people viewed this question
Top Dryers Experts
