Question about Refrigerators
I have a Whirlpool side/side with ice and water in the door. Ice is working fine but the water dispenser stopped working suddenly. I need to know how to get inside the door to find how to fix the problem. Or, if there is another way to repair it I would like to know that.
  • venables2 Nov 11, 2010
    It is Whirlpool ED25QT
  • venables2 Nov 14, 2010
    I intend to repair it myself and I do believe the solenoid has failed since there is no sound when I push the dispenser. The model number is Whirlpool ED25QT. I have not been able to get inside the panel and have been afraid to put too much pressure on it for fear of breaking it. I mostly need to know how to get inside the panel to inspect it and repair it. Does it clip on? Do you go through the back of the door? I see no screws or clips to guide me.
  • 15,935 Answers
The surrounding trim of the fountain simply snaps in place.
Start at one corner and work your way around to reveal the mounting screws.
It sounds as if the selector lever's microswitch has failed. It should audibly click when you press the lever.
Head over to repairclinic.com and enter in your full model number for replacement parts.
Thanks!
Posted on Nov 12, 2010
  • 3,267 Answers
Check if water is flowing into the water dispenser----- which means there is a problem with the inlet valve(water) and that is controlled by a solenoid Valve. If the solenoid is buckled up due to excess heating, get it replaced. If water is flowing in, the water dispenser's thermostat may have malfunctioned, since this thermostat is separate from that inside the fridge.
Posted on Nov 11, 2010
  • Refrigerators Master
  • 1,711 Answers
Could you please let us know your model
Ice maker stopped making ice, it just stopped. There is nothing blocking the outlet, no debris. The water dispenser still works fine but the ice maker is not working. I have a whirlpool 2665 refrigerator....
your ice maker unit is gone bad if you have warenty get them to replace the ice maker if not you need to do it :(
its coast +- 120$ :(
911service today . com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker stopped making ice.We have the Whirlpool Imperial Series with the water and ice in the door. The water dispenser is working fine.
The heater has a timer, and a temperature sensor. It senses when the water has turned to ice the temperature has reached certain degree. If the sensor or the timer malfunction then you would end up with the heater coming on too soon and the ice would not have time to freeze.
Nov 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker working, water stopped dispensing
This could indicate the water valve on back that sends water to ice maker is not working. The coil can be checked with an ohm meter. I also can help you diagnose the problem. Send the model number of your refrigerator so I can help you better, Thanks, Sea breeze seabreezehvac@yahoo.com
Below you can visit my site and enter model and part numbers in search feature, we offer free help and assistance.
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Dispenser
hi there,
check to see if you have a leak either on the inside or the outside of the freezer door.
check your icemaker line and see if anything is freezing up.
from the sounds of it, something is stopping the water flow into the icemaker.
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
WATER IN DOOR
bad solenoid assembly maybe
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
