Question about Brother HL-4070CDW Printer
I am trying to print photos and they come out too yellow
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Photo prints
Try cleaning mode on the printer, secondly a single color on a print or two or thre with one color noticeably absent means that that cfartridge is close on or is empty. EG Red Blue Yellow most of print is Ok but at end of print only blue seen means RED AND yellow are empty and only blue has some ink left. Replace ALL cartridges so your prints and paper arent wasted .
Jul 27, 2009 | Computers & Internet
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Canon Multipass F50 prints too much Yellow on photos
try realigning printer heads using the allingment on ya software look thru the printer manual to see how to hope this helps
Apr 12, 2009 | Canon MultiPASS F50 All-In-One InkJet...
R1800 printing way too green/yellow
I had a similar problem with my R800 . I got a colour profiler to fix it and he used a spyder. Made an amazing difference. Well worth the trouble especially if you are printing a lot of photos
jenni U.K.
Nov 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Photos print out yellow with black promanant on photo
try taking a photo where there is not so much light. see if this will help.
Oct 20, 2008 | Cameras
Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
Feb 18, 2007 | Dell 962 Photo All-In-One InkJet Printer
Photo Printer
sina, Does the photo print good using photo paper? How regular of a paper? Do all other colors have ink? What program are you printing the photo from? Have you tried printing from a different program? Some programs send varying information to printers. If all of the above has been tried...uninstall the printer and download the newest drivers from EPSON and re-install the printer. Good luck Tim
Feb 03, 2007 | Epson Stylus Photo 925 InkJet Printer
Brother HL-4070CDW Printer Logo
51 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
