Question about Whirlpool Refrigerators
Whirlpool Gold, Model #GI7FVCXWY01, Serial #KY4241799 Purchased in April 2010 This appliance is UNDER WARRANTY Ice maker stopped working; was serviced yesterday. It made a small amount of ice right away but stopped after technician left. Called for a re-visit this morning, but the service can't take place until Tuesday, 11/16. In the meantime, have noticed that the fresh food compartment in the refrigerator is FREEZING. Raised the temperature from 38 to 40, and turned the ice maker OFF once more. Will this solve the freezing problem until Tuesday? If not, is there anything else I can do? Or do I need emergency service? I can't get through to Whirlpool or the third-party servicer, A&E Factory Service, on the 800 numbers. All I hear are fast busy signals. As this appliance is under warranty, I hope Whirlpool will assume any charges for using this help service and/or fixing the problem.
5 Suggested Answers
  • 833 Answers
SOURCE: Gss25wgsd bb model number
Mick...there may be any number of reasons for this. First, check for a bad door gasket. It must be clean and fit snugly around the unit. Use a piece of typing paper about 2 inches wide to pull through. It should pull with some resistance anywhere you try. If it is gappy, humidity can leak in.
Next, make sure the condenser coils are clean. Third, how cold is your freezer? Is should be about 5 degrees or so if it is kept closed for about 6 hours or more.
Is the ice maker clean and not overflowing? Many units can be removed and cleaned out.
You may have other issues...start with these.
Posted on Dec 18, 2007
  • 71 Answers
SOURCE: Ice maker is leaking small amounts of water.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
Posted on Dec 14, 2008
  • 6 Answers
SOURCE: Whirlpool Gold Refrigerator (GS5SHAXNLOO)
check the water supply and filter
Posted on Apr 26, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: GE Profile PFSS6PKWASS ice maker quit, water and
Try defrosting it completely then re start it again. Shut off the water suplly. Maybe the service guy forgot to turn the water supply off.
Posted on Jul 07, 2010
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker cubes haning up stopping ice production
Bob Ray, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Bob Ray), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our Whirlpool Gold refrigerator is not getting cold and it is defrosted. The compressor is very hot. Our ice maker stopped working about six months ago and we replaced the cellinoid but it didn't fi
your Whirlpool has lost its gas charge , you will require a refrigeration mechanic to repair or if under warranty tell them to exchange it .
May 10, 2009 | Refrigerators
Ice maker is not working
hi. thanks for the question. because the door was left open . moisture got into the small tube that lets water in to the ice maker.. and froze. use hair dryer to thaw the tube. remove and clean. thanks the appliance doc. please rate me
Sep 11, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
335 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
