Question about ASUS Eee PC 901 Notebook
Is it possible to merge the two partitioned hard drives?
How do I merge adjacent partitions on my HDD?
You can delete all the partitions on the hard drive and then create a new single partition then format this partition.
Mar 31, 2013 | Computers & Internet
How do i merge my partitions on my hard drive
Use partition management software which support merge - easus or minitool partition manager are excellent freeware solutions.
Best practice would be to have at least 10 % free space.
Sep 14, 2011 | Computers & Internet
How do i use my second partition of my hard drive? my laptop is a dell vostro 1088. It seems that my OS (C:) is full but i see that i have a new volume(F:) so how do i use that? Originally, my laptop...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 23, 2011 | SIB 320GB 5400RPM 8MB Cache SATA Hard Disk...
I need more space on my laptop
ahaaahhhhhhh......... you mention your partition drive D is completly empty...transfer your drive C files to your drive D. by that you can free space in your DRive C and also right now you are experiencing slow in operation of your laptop ryt? its because Drive C is almost full and your drive C is the partition where your operating system installed...
about your question of combining the drive c and D yes it is possible. for for me you have already the advantege setup currently i yopur laptop all you need to do is balence your files... make your drive D your storage files. your back up area. like your personal files, pictures, music, videos transfer it to drive D
Oct 08, 2009 | Acer Aspire 4720 Notebook
Unable to merge c and d drives
Dear! Use partition magic v8.0 or 8.2 softwawre, there is very easy to merge your drives.
Good Luck
Sep 28, 2009 | ASUS Eee 4G Notebook
Is there a way to merge a partition with another partition, my new internal hard drive is split in two, and i cant figure a way to combine them, is there a way?
why do you want to merg them. yes you can but you cant un do it un less you reformat your hard drive. it is a good thing to have different partitions if one fails the data on the othe partition is safe
Jun 24, 2009 | Computers & Internet
How can I merge two Hard Drive partitions together?
Nearly any partitioning software, even the built-in found on an XP install disk can repartition your drive. Partition magic is easier to work with. You can also find partitioning utilities at most hard drive manufacturer's websites. Or check out some of the shareware utilities here.
There is always a risk of losing ALL data on the drive when you repartition. It is likely the two recovery partitions are quite small. If the data on the drive is important it may be wise to leave it as is and simply buy an additional drive.
Jan 25, 2009 | Computers & Internet
Running out of space on C drive
hi, its possible to merge two partitions.
down load a partition changing software like partition magic and install it. Have a look at the help available and and go for merge partition.
thank you
Aug 15, 2008 | Microsoft Windows XP Home Edition
Hard drive
You can install a software called partition magic and use it to merge the two partitions into one.
But you might need to free some space on your C drive. What you can do is copy (CUT) all your My Documents data and paste it to your D drive or your second drive. This should free a lot of space enough to install partition magic.
You can download the trial version software from http://www.soft32.com/download_151.html
Install it and merge your partitions and then you can uninstall or purchase if you want.
Lolita
Apr 08, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Cant reboot win.98se after using partition magic 6.0 to merge adjacent partition to c. drive
how large the capacity of your hard disk drive? it is possible that would be the problem it is too dangerous that it will lead your hard disk to crash the system and damage the disk itseld that can create bad sectors on your disk. If you want to partition your hard drive, run the FDISK utility instead.
Feb 07, 2008 | Dell Dimension 3000 PC Desktop
ASUS Eee PC 901 Notebook Logo
233 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
