Question about Keurig B60 Coffee Maker
My keurig will not brew. It says it is brewing but the water level is not going down and it is not brewing
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
My issue is that it says its brewing, it sounds like its not pumping water and it just stay stuck on "Brewing" and doing nothing! We solved this by unplugging, not just turning off!
Posted on Nov 02, 2012
    Problem Solver:
  • 12 Answers
Ok if the Kcup is filling up but nothing is coming out but it will come out if your run straight water then the bottom piercing needle is plugged up with coffee grounds. Take out the K-Cup holder, snap off the bottom part of the holder and using a tooth pick or needle push it thru the bottom side of the lower piercing needle. It will get clogged with grounds after a while of use!
Posted on Aug 05, 2012
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
I have a Keurig Vue. I have descaled and cleaned the product on schedule but it leaks water from all around the brew head and only 5-6 oz of coffee make it into the mug. I tried to clean out the pin also...
Remove and clean the Brew Head, with the V700 the way to remove would be to open the lid with the handle, place your fingers around the Brew Head, there are tabs to each side, press tabs and pull down and toward you. Wash this out thoroughly in your kitchen sink. Now before replacing the Brew Head, with the handled lid up, turn the back of the brewer so that it is facing you...Look straight down into the top of the brewer, you will see the needles, use an old toothbrush to clean them. Replace the Brew Head and descale the brewer with White Vinegar (do NOT dilute with water) or Keurig descale solution (purchased only through their website). The video to watch the descale instructions is: www.keurig.com/customerservice
Hope this helps!
Oct 28, 2013 | Keurig Vue V700 Brewing System - 110774
Keurig not brewing
Our unit (the mini) would only blink red but would not brew. It didn't make any noise and seemed like it was dead. To fix this, leave the unit plugged in but powered off. If you haven't already done so, add water to the top of the unit and then open the pod holder so that the water flows into the internal storage tank. Hold the brew button in (don't let go until it is done brewing) and the light will turn on - after a while it will start brewing. Let go of the button once it has finished brewing. According to a Keurig rep - this problem is often caused by using cold water straight from the fridge.
Sep 17, 2013 | Keurig Coffee Makers & Espresso Machines
I set the brew size on the Keurig, but can't figure out how to get the lights to stop blinking and make the coffeemaker actually brew me a cup of coffee. I've held down the brew button, thinking that would...
the blinking blue lights, means the water level is low...BUT sometimes it sticks, if the tank is not clean..its that round disk, on the side of the water tanks that sticks..try resetting the tank..set set the default brew size..goto menu, then goto brewsize to set the default size...when it says ready to brew..then you can select the size...
Dec 18, 2010 | Keurig B70 Coffee Maker
My keurig won't brew a full cup for the 10oz option, but it brews a full cup for the other options.
This sounds like a water level sensor inside the unit. If it's under warranty... call Keurig and they might send a replacement... out of warranty requires you to open the unit and re-seat the harness that comes off of the water level array into a circuit board... low voltage thing...taking it apart is not easy, but I have explained it in another answer... for a B70 unit...
May 05, 2010 | Keurig B50 Coffee Maker
My Keurig B66 is not pumping or sucking the water to brew. It will brew a cup here and there but not the way it should. There is plenty of water in the reservoir. You can hear it trying to pump the water...
I had the same problem. I called Keurig at 1-866-901-2739 and they are sending a replacement machine to me as they said this problem is not repairable.
Apr 09, 2010 | Keurig B60 Coffee Maker
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Continually running/heating
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Mar 31, 2008 | Keurig B50 Coffee Maker
Keurig B60 Coffee Maker Logo
7,576 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
