Question about Dell OptiPlex GX280 PC Desktop
Problem when windows XP is starting up. Isass.exe - System Error
When windows is staring up, the computer show me a message "Isass.exe - System Error" An invalid parameter was passed to a service or function.
After press ok... the computer re start itself.
  • 191 Answers
To work around this issue, restart your computer in Safe Mode. To restart your computer in Safe Mode, press F8 when the computer starts. Then, when the computer is in Safe Mode, add the System Pages entry to the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Memory ManagementTo add this registry entry, follow these steps: 1. Log on by using an account that has administrative credentials. 2. Click Start, click Run, type regedit, and then click OK. 3. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management 4. On the Edit menu, point to New, and then click DWORD value. 5. Type SystemPages, and then press ENTER. 6. On the Edit menu, click Modify. 7. Click Decimal, type 31000, and then click OK. 8. Quit Registry Editor.
Posted on Jun 17, 2008
Isass.exe application error
Try this do this when the bios is booting up before the windows.. press F8 then start windows in safemode with command and pronpt then after that on the blackscreen if command and prompt type this
chkdsk /f or chkdsk /r
then press enter
then press Y and enter and reboot the computer and wait for it to repair the errors
plese let me know it this work.
Feb 21, 2010 | HP Hewlett Packard Pavilion dv6000z PC...
I have a dell dimension 2400 with windows xp profewssional. When I try to turn the system on i get an isass.exe application error that says the application failed to initialize properly (oxc0000005). click...
if you have a window xp disk put it in start the machinfne and when it ask you to replace or repair windows you want to repair window xp hope this help .........................
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
Hi
Its seems like some of the windows files are corrupted, you will need to repair windows.
You need a windows xp cd to do
Good Luck!
Mar 27, 2009 | Computers & Internet
Spysweeper program damaged after a.exe download
isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
How Do You Remove Isass.exe Files in Windows XP and Vista:
  1. Click your Windows Start menu, and from “Search,” click “For Files and Folders….”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a Isass.exe file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop Isass.exe processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys ALT + CTRL + DELETE or CTRL + Shift + ESC.
  3. Click Processes tab, and find Isass.exe processes.
  4. Once you’ve found the Isass.exe processes, right-click them and select “End Process” to kill Isass.exe.
How to remove Isass.exe registry keys: (Do not delete anything other than what is listed below.)
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any Isass.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Isass.exe’s registry keys.
  4. As soon as Isass.exe registry key appears, you can delete the Isass.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Isass.exe DLL files:
  1. First locate Isass.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Isass.exe DLL file is located. If you’re not sure if the Isass.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the Isass.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Isass.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Isass.exe change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Block Isass.exe sites: www.eKerberos.com
Stop Isass.exe processes:
Get rid of Isass.exe DLLs: %PROGRAM_FILES%\ eKerberos\ Hook.dll
Delete Isass.exe folders: %PROGRAM_FILES%\ eKerberos\
Please rate this a fixya
Feb 08, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
Dell OptiPlex GX280 PC Desktop Logo
167 people viewed this question
Alun Cox
