Question about HTC TyTN II Smartphone
My tytn11 does not want to start up. Only shows smart mobility in middle os screen and R G D on bottom right of screen. I tried soft and hard restart, but it doesn't work
4 Suggested Answers
  • 13433 Answers
SOURCE: Is It BRICKED???
possibly a software corruption, the rom would need to be reloaded, or then theres a hardware problem.
Posted on Jun 01, 2008
SOURCE: My tytn11 touch screen does
I have sent my Tytn2 in to have it repaired. Seems as if it could be the screen which has to be replaced at +- SaR 95.00 or the flexi at SaR 650.00. So in a panic I spent the $12.95 to subscribe to this site unnecessarily
Posted on Jan 20, 2010
asber
  • 291 Answers
SOURCE: After changing registry unable to boot the mobile.
try to remove the battery first and reinsert it and switch it on, if it still doesn't boot, then remove your sim and memory card, try to reflash your back up firmware, this is if you know how to reflash it, if you don't know how to reflash your phone, try reading tutorials and join some forums. in this case you will have an idea on how to reflash it, but let me remind you, you will do this on your own risk, effects of wrong flashing would be a dead and useless phone. so if you are having a second thought, go to your service center, and just tell them that your phone just suddenly stop working. they will reflash it for you.
take care.
Posted on Feb 23, 2010
My htc touch p3450 is not starting.it is showing smart mobility nd then turn off autumatically..what to do
You can try resetting the fone. try a soft reset first, by pressing down the reset button with the stylus. if that doesnt help try a hard reset. To perform a hard reset, first hold down the Talk and End keys together and then press the reset button with the stylus. Release the reset button, but continue pressing the Talk and End keys until you see this message on the screen :"This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel". Release the Talk and End keys and press the Enter key on the fone. It will be back to factory settings.
Thank you.
Dec 08, 2010 | HTC Touch P3450 Smartphone
MY HTC touch dual can not go past smart mobility start up screen on start up.
can you help me on this guys i do the hard reset and the soft reset but still on freezing on start up? what should i do someone tell me that my device is over used should i reprogram it??
Sep 29, 2010 | HTC Touch P3450 Smartphone
My tytn11 touch screen does not respond to screen taps. Everytheng else works. Navigation control and all buttons work. Have tried soft reset and screen aligning to no avail. Advice will be appreciated
Jan 19, 2010 | HTC TyTN II Smartphone
Cant remember password to get in to phone
You can hard reset the device which will bust past this flimsy password.
To do this:
Press and hold the left and right soft keys under the screen while you push the reset button on the bottom of the phone with the stylus or a similar object.
May 24, 2009 | AT&T 8925 Tilt Smartphone
Cannot hard reset XDA orbit - Forgot password
1.Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom center part of your device.
2.Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: "Press SEND to restore factory default, press END to quit."
3.Press on your device.
On my XDA the reset button is located on the left bottom side of the XDA.
Apr 02, 2009 | O2 Xda Orbit Smartphone
Hard disk error
Unfortunately this error occurs with a fault hard drive. You will need to replace the hard drive and then reinstall the OS.
Mar 20, 2009 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
HTC screen will not show
Have you tried just pulling the battery out for a few seconds, and replacing it. Letting it reboot and start again. You do wanna do this at least three-four times a week.
If the powercycle doesn't do thte trick, you'll wanna do the hard/master reset. As per www.htcwiki.com
Hard/Master Reset for a HTC Pocket PC: Warning: Performing a Hard/Master Reset will remove all of your data (settings, files, 3rd party applciations, etc.) from your device and will only reload the Windows Mobile Software and components. The method for Hard Resetting/performing a Master Reset on HTC devices can vary by model. Below are the instructions for the most common method. If these steps do not work for you, consult your user manual or contact your wireless carrier for additional assistance.
  • With the device powered on, press and hold the Left and Right Soft Keys.
  • Whilst holding the Left and Right Soft Keys, perfrom a Soft Reset on the device by inserting the stylus into the reset hole.
Feb 03, 2009 | HTC PPC-6800 Smartphone
My password is not unlocking my t wing
you need to do a hard reset. this will reset the phone but it will also delete all memory
!- hold the two soft key(upper right and left key on keypad under screen)
2- while holding soft keys, insert stylus rset hole next to charging port on bottom of phone.
3. you will be given option screen to clear memory
Nov 04, 2008 | T-Mobile Wing™ Smartphone
Not reading properly
You might try adjusting the Grayline setting. It's purpose it to distinguish between hard & soft bottoms. Press MENU, select GRAYLINE, the scale appears like when adjusting sensitivity you can adjust up or down with arrow keys. Get over a non reading soft bottom then adjust. The change is reflected on the screen as you adjust it.
Jul 08, 2008 | Lowrance LC X-15MT Sonar
Spv m3100 re boot
Have you tried doing a hard rest. Here is the procedure;
Caution if you perform a full reset, your phone returns to its default settings and looses all information that is saved on phone (Like contacts, messages, emails, mms etc).
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
May 01, 2008 | Orange SPV M3100 Smartphone
HTC TyTN II Smartphone Logo
79 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
