Question about Sony Playstation 3 (PS3) Console
On turning on my PS3 it comes up hard disk's file system is corrupted and will be restored. It prompts you to press x and OK. Once it completes the restore to 100% it returns to this screen. Any help would be really appreciated. Many Thanks
  • 1,472 Answers
Sandyandhayl
If the building PS3 repair options do not fix the issue then you will need to pull the hard drive from your PS3 and format it with your computer. The link below will help you do this. Note if this does not fix the problem then you will need to replace your hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Nov 12, 2010
PS3 says ''The hard disk's file system is corrupted and will be restored'' We press OK and the system says its restoring. When restored it comes up with the same message.
You need to restore your hard drive manually by connecting your hard drive to a computer, once installed you must select the hard drive and format it. once done you must format again but as FAT 32 and Done
For more help check us out at
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on, it says hard disk file system is corrupted and will be restored, I press OK, it gets all the way to 100%, then it restarts and tells me the same thing. What do I do?
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    "The Hard Disk's file system is corrupted and will be restored"
    rpoulley
    If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
    Issken
    Mar 07, 2010 | Sony PlayStation® 3 (80GB) Console
    When switched on a message comes up.THE HARD DISKS FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED. PRESS THE PS BUTTON TO USE THE CONTROLLER. X ENTER. restoring do not turn off. once this is complete the...
    Easy fix. Hold down the power button on the system until it turns red. Release, and repeat. Release and repeat, only this time wait until you hear 2 quick beeps. Release quickly and then you go into Safe Mode, Choose option 5, PS3 System Restore. This will also reformat your disk. System will automatically restart when you complete the system setup. Only warning is you lose all login info and possibly content you have downloaded. You are done.
    Jan 23, 2010 | Sony Playstation 3 (PS3) Console
    Hard Disk Corrupted
    you need to send the ps3 to sony so they can reset the hard drive and format the system
    Dec 11, 2009 | Sony Playstation 3 (PS3) Console
    Hard disk's file system is corrupted.
    Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
    Check out ccgamingonline.com
    They give you free estimates for your broken system.
    May 09, 2009 | Sony Playstation 3 (PS3) Console
    Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
    Mar 13, 2009 | Sony Playstation 3 (PS3) Console
    apart from physically reformating the hard drive yourself (taking it out and loading it on laptop or desktop and format, at your own risk), there isn't much else you can do. If the console is still guaranteed then contact sony and they will send you a new one.
    If you do format it your self when you replace it in your ps3 you will need to format it again using thier options.
    Nov 15, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
