Question about IBM ThinkPad T20 2647 Notebook
IBM THINKPAD TYPE 2647 AND I CANNOT MAKE WIRELESS CONNECTION
SOURCE: free ibm t21 2647-4bu restore cd download.
i have problem with my t21, it always hang up after several minutes,dont know what makes it freeze,it happens after i installed xp prof. help please
Posted on Jan 19, 2008
geekofcomp
  • 47 Answers
SOURCE: IBM thinkpad 2647 T21 LAN Card Driver files needed...
if you are using the internal LAN card to connect to the cable modem, no additional drivers will be needed. However, you would need to configure TCP/IP settings to use a DHCP server to automatically configure the IP address. you would also need to check whether or not you have the right CAT-5 cable. you might need to buy a crossover cable.
hope this helps
Posted on Apr 08, 2008
SYSTEM ONE
  • 85 Answers
SOURCE: Wireless network connection on IBM Thinkpad
Ok when looking at your question i became very currious as to the answer myself so i did a litttle research and i think maybe the info on this page here: http://www.eggheadcafe.com/software/aspnet/33307589/certificate-required-to-c.aspx
could be of some use to you . even though the link describes a diferent network adapter the information there is about the same exact error on a router of the same type
I hope this information helps ... if it does not then let me know and i will find some more answers since i used to have the exact same laptop that you have now R40
Posted on Nov 20, 2008
  • 848 Answers
SOURCE: bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: IBM THINKPAD TYPE 2647
ibm think pad type 2647 bios reset
Posted on Jul 18, 2009
Ibm thinkpad 2647 vga driver
hello download your drivers from here www.ma-config.com
Jun 19, 2011 | IBM ThinkPad T22 2647 Notebook
Can't get wireless to hook up to my ibm thinkPad
if your using an office internet connection use the proxy server to connect..
Feb 19, 2011 | IBM ThinkPad T20 2647 Notebook
I just purchased an IBM Laptop model T23-type 2647 and I need to find where my wireless connection switch is located to turn the wireless connection on, can you help me?
Unless I'm very much confused, this laptop does not have WiFi wireless capabilities as provided by the manufacturer.
I checked the user manual for this laptop, and there is not mention of built-in WiFi capability.
It may be that the laptop has an add-on PCMCIA card that supports WiFi. In that case, you would need the software that came with the adapter or download the software from the vender's web site.
This is the location that I found the user manual: HERE
Dec 27, 2010 | IBM ThinkPad T23 2647 Notebook
I pressed Fn +F5 on thinkpad R61 but wireless cant be on
in run window type ncpa.cpl and got to wireless adptor and enable the connection if it is disable.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 09, 2010 | IBM ThinkPad T23 2647 Notebook
Hi, where is the wirelesss switch in IBM Thinkpad T 2467
Should be on top of keyboard or under the screen.
You can also go into search menu and type in wireless assistant and it will turn it on too.
Sep 08, 2010 | IBM ThinkPad T23 2647 Notebook
Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
I bought a used IBM Thinkpad T20 - is the wireless card built-in
This Notebook doesn't come with abuilt in wireless , so you need to get a wireless adapter for this if you want to make it work wirelessly you can get this one from Linksys WPC54G or WUSB54GC. By the way this is the complete specs of your laptop http://www.dealtime.com/xPF-IBM-ThinkPad-T20-2647-264745U
Nov 14, 2008 | IBM ThinkPad T20 2647 Notebook
Internet Connection
A few years ago, i too had an IBM thinkpad and encountered some issues as well when connecting to the internet.
The IBM 2647 does not have a built in wireless card, meaning that you need to purchase one from your local electronics store to use wireless internet. The software provided with these CD's can often be quite helpful and will help you set up the connection.
The 2647 only supports an analog modem connection, and the modem in the area you are attempting to connect via ethernet may use a digital modem. Adapters are available although they are quite pricey (ranging from $200 and up.)
Hope this helps.
FerrariXP
Mar 10, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
57 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
