Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Start button plastic is gone and cant push it on
  • 4,323 Answers
Hi
You'll need to replace the overlay screen if you need the washer keypad to work. In case the moisture has entered inside the keypad you may need to replace the electronic control assembly. Please check part#6 (overlay) and part#7 (electronic control) in the diagram---
You can buy the parts from this link---
Kenmore 2.1 cu. ft. Compact Portable Top Load Washer Parts
Hope this helps... Please post back if you need more information.
Daniel
Posted on Nov 11, 2010
Start button gone how to start model number WED9200SQO
Call a repair service to replace missing start button
Aug 13, 2015 | Whirlpool Dryers
Product code is KISITD1. Its temperamental. Doesn't always start. Today it stopped working 20 mins into a 60 min cycle. Then it started for a cpouple of times , now it wont work at all. Have taken it...
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Mar 21, 2015 | Dryers
Why cant I get windows 7 to start up
That's all the info you give us? Why won't it start?
Maybe the computer isn't plugged in. Did you try and push the power button? Could be a virus. Power supply might be bad. Sometimes Windows just gets corrupted and needs to be reloaded. Your hard drive might have gone bad. The RAM might have gone bad. Motherboard may have gone bad. Power button my have broke. Something might have come unplugged inside.
Aug 30, 2014 | Computers & Internet
My kenmore electric dryer model 11060927990 will not start when I push the start button
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Aug 01, 2014 | Kenmore Dryers
I have same tv but the on/off button has broken and cant start the tv
On some models, there's a plastic piece which pivots, pushing the actual button itself. If you can take the back panel off and inspect it, you may find you can replace the little piece of plastic with something similar or use super glue to fix the button itself. Or you might be able to swap out the "info" button (or some other button you don't use as much) with the power button
Mar 27, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I cannot turn on my coby MP605-4G on and my power button is gone and I need to turn it on!
Hi, I have a Coby2Gb model MPC7095 and exactly the same thing happened. From your video it looks very similar.
The on/off button on mine is on the top right side, and on inspection it is a plastic rocker which operates a switch on the frontupper right corner, when the plastic on.off button fell off I took it apart and drilled a 2mm hole in the front cover 5mm down and 5mm in which now gives access to the on/off button, so I now turn mine on with a paper clip which is bent round the head phone cable.
Looks like you have started to take it apart already, so if under where the on/off button used to be a thing which quietly clicks or pops when you push it, drill that hole!
Good luck
Dec 04, 2012 | Audio Players & Recorders
Cant seem to be able to get my local channels. i have a 52
I would suspect all the stations have gone away from over the air broadcast or gone digital for antenna reception---there are boxes available which will convert so the antenna can still be used.
May 21, 2012 | JVC Televison & Video
My 2001 nissan frontier 4x4 cruise control will not activate even though the cruise light will display. it will not lock into cruise. Where do I start checking for possible problems?
look for any loose or corroded wires and failin vacuum hoses in engine area--u need to get it code scanned even if there r no warning lites
Dec 30, 2009 | 2001 Nissan Frontier Crew Cab
Hi, The dial doesn't turn anymore and you have to push it in hard and try and work out what setting it is on. Also the start/hold to reset button has to be pushed several times to get it to start and has...
You have probably dislodged the plastic moulding in the control module that hold the buttons in place, you will have to remove top cover, soap dispenser draw, and front panel to gain access to the control module.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint WMA32 Front Load Washer
On / off switch on Dell D-505
Take off the plastic strip with the power button on it. It will pull up on the right side and snap up and off. Then try starting it by pushing the power button on the board. If you have to press this button hard then it's worn out and will have to be replaced. If you don't have to press hard then the power button in the plastic strip is worn and misaligned and the plastic strip needs to be replaced.
Jun 26, 2008 | Dell Latitude D505 Notebook
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
75 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
