Question about Zyxel ZyAIR G-2000 Wireless Router
I try to conect my Zyair2000 to a ADSL-midem in bridge mode. I put to the WAN section PPPoE, right user and password. Zyxel becomes no fix address. BUT when I conect the bridge-modem with my PC and do a PPPoE is work. Why can not Zyxel do this? marcuma
tpvijay
  • 34 Answers
SOURCE: Zyxel Bridge Mode Help!
Here are the information to configure Zyxel as bridge
http://www.zyxel.com/web/support_knowledgebase_detail.php?KnowledgeBaseID=3104&pid=20040812093058
With Regards,
TPV
Posted on Jan 26, 2008
tpvijay
  • 34 Answers
SOURCE: Bridging of a Zyxel prestige 600 router
With Regards,
TPV
Posted on Jan 27, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
HAAi
  • 77 Answers
SOURCE: ZyXel P660HW-T1 ... Problem bridging 2 wirless adsl routers
What do you mean by "wireless bridging"? Does it mean wirelessly connecting both routers? (ex. Zyxel is at location A and Micronet ais at Location B and you'll wirelessly connect them). If this is what you mean, then it might not be possible since those are two different brands and possibility is that they will not work with each other when they're wirelessly connected unless one or both routers have the capability to do so.
Posted on May 09, 2008
  • 9 Answers
SOURCE: ADSL Router wont get ip address from operator
sir if your ISP account is PPPoE or using username and password to connect, try to open your router using web interface configuration, locate your account and try to disconnect then connect.  hard reset afterwards(on/off the device)
if your using a dynamic account, try to RESET your modem and do the hard reset.  check your IP using command prompt, to do this type ipconfig /release, when it releases to zeros, type ipconfig /renew to have your IP's back...check internet connection then
Winsor
Posted on Sep 02, 2008
Linksys RV042 Router and AT&T Static IP's
How were you advised you have 5 more sticky IP addresses? Are you talking about LEGAL IP addresses? If so, all you need to do is program your PC with one of the addresses manually and set the router as your default gateway. I assume you know your DNS server details? If not, use Google free ones 8.8.8.8 and 8.8.4.4.
I hope you have firewalls on your systems!
Mar 15, 2010 | Linksys RV042 VPN Router
Hello. I've setup a LAN of 2 computers, a router and a ADSL modem at home, but when I plug both computers to the DLink 524 router, all the lights become less bright and I can't connect to the router, even...
reset set the modem first. then connect the one system to adsl modem. type 192.168.1.1 in browser. enter user name&password.go to interface setup tab-internet--select bridge mode--save and reboot. now remove that take router connect to system type 192.168.1.1 in browser. enter user name&password.go to interface setup or advance setup in that wan tab or internet tab select dynamic ip and lan page give different network address eg-10.0.0.1 for router 10.0.0.2-...254,255.0.0.0,10.0.0.1 save and reboot it will work or just call 08041478653 , 9740575949
Feb 25, 2010 | D-Link AirPlus DI-524 Wireless Router
How do I bridge mode a ZyXEL 600 series ? help please
Try setting both internal and external interfaces to DHCP rather than static, or if you have legal static IP address put it on INTERNAL interface only.and leave external as automatic.
Feb 24, 2010 | Zyxel Prestige 650HW - ADSL Router...
I put it in bridge mode and can't but it back into routing mode (tried to fix NAT problems) tried using the default 192.168.1.1 and then command prompt to find the ip that way to no avail? any ideas?
hello Cadmb3220
Of course it won't work :)
Once you set your zyxel in bridge mode all it does is translating adsl signal to comething that any other pppoe ethernet device can understand.
so in this bridged mode zyxel has no IP, is not manageable and can't be accesed over an ip ...
only way to access it again is to do a factory reset ...
btw ... i'm almost sure that whatever nat problem you had - you had because you didn0t make the same rule in your firewall on the zyxel :)
Feb 17, 2010 | Zyxel P660HW-D1 Router
I was helping a friend who has Earthlink DSL (a ZyXel DSL modem) to get her Linksys WRT160N wireless router working with the Earthlink modem. No luck. Earthlink won't help unless you pay $7.95/mo with a...
Hello mcneel,
The router should use the ZyXEL P600 as it's DHPC Server. And review/update the ZyXEL WAN configuration as follows:
• Log on to the ZyXEL P600 browser configuration interface: 192.168.1.1
• Enter username/password: Default is username:admin - password:1234
• Click '+' by Network in the letf-hand panel
• Click WAN
• In the Internet Connection tab, select the following options:
Name - (Any Name)
Mode - (Routing)
Encapsulation - PPPoE
User Name - (ISP login username eg. MyName@isp.com)
Password - (ISP Login password)
Service Name - (Leave Blank)
Multiplexing - (LLC)
Virtual Circuit ID
VPI - (Leave Blank: Issued by ISP)
VCI - (Leave Blank: Issued by ISP)
IP Address
Obtain an IP Address Automatically - ([X] Check this option)
Static IP Address - (Not Selected)
IP AddressI - (Leave Blank)
Connection
Nailed-Up Connection - ([X] Check this option)
Connect on Demand Max Idle Timeout sec
• Click 'Apply' button
• Close the browser configuration interface page
Finally, this link to the EarthLink DSL FAQ Setup Installation and Configuration page might offer some useful suggestions:
http://www.dslreports.com/faq/earthlink/30_Setup_Installation_and_Configuration
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Zyxel Prestige 645M (AM408405) Bridge
Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Oct 21, 2009 | Zyxel Prestige 660HW Wireless Router...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Winsor
Sep 02, 2008 | Zyxel P660HW-D1 Router
Siemens ADSL Modem (model SL2_141) networking
i m reset the setting in my modem
my modem no is - sl2_141
192.168.1.1 this site is not open
plz solve my prob...
Jan 30, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
What do I need to use the P310?
You need a ADSL modem or cable modem with an Ethernet port to use the P310. The P310 has two Ethernet ports: LAN port and WAN port. You should connect the computer to the LAN port and connect the external modem to the WAN port. If the ISP uses PPPoE or RoadRunner Authentication you need the user account to enter in the P310.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Open Questions:
Zyxel ZyAIR G-2000 Wireless Router Logo
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
