Question about Verbatim VER95327 USB Hard Drive
Verbatim 320 gb usb external hard drive stopped working.When the device is connected the blue led light is on.But computer is not recognizing.Help me.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
My portable hard drive wont connect to my computer. When I plug it in a blue light on the device light up, and it makes a constant beeping sound, but my computer does not register the device. It works on...
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
May 05, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
Hi, I have just rebooted my PC, and find myself missing the driver to my Verbatim Hardrive 320 GB. Is it possible to download a new driver, so I again can watch all my pictures I have saved? Hope you can...
No driver is needed, it's just a basic USB external memory. If you get a message about a driver then the pc no longer recognizes it correctly, which means that it has failed.
Your only hope of maybe recovering some data out of it is to dismantle the unit, extract the actual hard disk from within and connect it directly in a desktop - access it from My Computer.
Feb 07, 2011 | Verbatim 320GB USB Portable Hard Drive
Hello, my external harddrive (Verbatim, 500GB USB/FW800) stopped working. When connected the blue LED lights up. After 3 sec it goes into flash mode. The HHD makes a clicking sound. The MAC Hard disc...
> the HDD makes a clicking sound.
That's a very bad sign. :-(
> find a way to rescue the [files]
Search online for a professional "data recovery service". For a significant fee,
they can repair your disk-drive, just long-enough to copy your files onto a brand-new disk-drive.
Nov 03, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
I CONNECT EXTERNAL HARD DRIVE TO PC WITH XP AND IT DID NOT RECOGNISE EXT HARD DRIVE HELP PLEASE
dear sir
good day
try to replace the USB cable and test the Hdd on an other computer system to make sure it is function and good luck
Dec 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
Usb device not recognized, usb device malfunction windows does not recognize it
Connect it to a different computer, to see if the USB port on your computer was the problem, or if the USB device itself is the problem.
Dec 25, 2009 | Verbatim External, USB 2.0, 750GB...
My verbatim usb external hard drive quit working on only one of my computers. I tried using computer management but it doesn't recognize it there. it does show up as Toshiba in the device manager but...
The brand of your HD is Verbatim, so it should not show up as Toshiba in the Device Manager. Your computer is detecting another device.
Please do not rely on the Device Manager, you have to check the Disk Management instead. If the HD did not show up in the Disk Management, try connecting the HD into another USB ports of the problem computer. It could only be the USB ports of the problem computer is bad.
How many computers do you have? If you have 3 PCs and only one computer is having a problem, then you might need to update the USB driver of the problem computer.
Have a great day!
Sep 04, 2009 | Verbatim 160GB USB FireLite: The "drive...
I can´t see the portable hard drive unit in my pc
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Feb 18, 2009 | Verbatim External, USB 2.0, 750GB...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim VER95327 USB Hard Drive Logo
359 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
