Question about Sony Ericsson K800i Cellular Phone
BLUETOOTH HEADSET NOT WORKING
Hi there, My bluetooth headset has suddenly stopped transmitting sound from the phone. The connection is there and the menu 'transfer sound to phone' comes up - but its already in the phone and not the headset. Have tried two other headsets but still no audio? Any ideas?
Oh will try when get home! Thanks for the advice - just one thing though - the sound has gone totally on the phone now - no ringing when calls come in, no sound when alarm is meant to ring, nothing when texts arrive???? Have checked it's not on silent so guess it could all be connected......have I got a duff handset????
Posted on Jun 19, 2008
    Guru:
  • 859 Answers
You may try this, but it may make no difference so please don't take it hard.
When you are in the transfer sound menu of your phone, press and hold the key on your headset for five full seconds.
You may also have to go through the connect to device menu all over again and choose remove device and then add device, the pin code is usually all zeros.
If this helps you good. If not, please don't rate this solution but respond using the comment box below. There are other things to do, just try this first.
Regards,
Worldvet
Posted on Jun 17, 2008
Ex119 bluetooth
Bluetooth must be on and connected to phone in order to take call from headset.
Mark
Motorola Support
Apr 20, 2014 | Motorola Mobility Ex119 Ex-119 Dual-sim...
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
My Bluetooth headset's microphone stopped working
Same Problem Here. Restored the 8220 flipphone to factory settings. Dint work either.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Bluetooth headset problem
There are two types of profiles that Bluetooth headsets uses. One, it is called the A2DP (Advanced Digital Profile) and second is called the Headset profile (Mono).
The A2DP is used for listening music that's transmitted from the phone to the headset.
The Headset profile is used for calling. But the A2DP can also be used for calling if the phone or the headset support it.
If one of your device (either the phone or the headset) doesn't support it, then that could be the reason why you couldn't hear the sound.
If both devices support A2DP, make sure that your headset is connected to the phone via the A2DP profile.
You need to refer to the phone manual to see if it's supported by your phone and how to connect to it.
Hope I explained it properly. Have a great day!
Jun 22, 2009 | HTC G1
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
Oct 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Lost manual
Since it was already paired with your cell phone it should show up in your phones bluetooth device list, it should be as easy as navigating to the bluetooth settings in your phone (usually found in tools) and selecting the Voyager 520 and selecting the connect button. Give it a try as I have to reconnect mine periodically also.
Aug 07, 2008 | Plantronics Hama Voyager 520 Bluetooth...
Bluetooth has stopped transmitting
Make sure your version of bluetooth for the hand held device and the listening device is not an old version. The first generation of blue tooth was able to transmit sound (for phone calls), but not able to transmit stero sound or mp3.
Sorry I couldn't be more helpful... :)
Dec 11, 2007 | RIM BlackBerry 7100G Smartphone
Sony Ericsson K800i Cellular Phone Logo
80 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
