Question about Dmm Vision Fitness T9500 Treadmill
Hello! i have a vision fitness running treadmill. It's older but in good working condition. Everything has been great, except I noticed that the belt started to get a large vertical wrinkle in it, I stopped and loosened the belt to fix the problem. But when i retightened it and ran it it wrinkled and bunched to one side after 15 minutes of running. now I cant get the wrinkles to stay away and stop the treamill from bunching up. What shoudl I do? Ive tried readjusting the tension, on both sides, one side, the other side.... why is it doing this? thanks -lindsay
maxtreadmill
  • 832 Answers
SOURCE: squeals on startup for about 1 minute then goes
Remove motor shroud and inspect the drive belt VF is imfamous for squealing drive belts better to call them and order a new belt here is their # 1-800-335 4348 Vision is now under there parent corp. name Johnson
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: my vision fitness t9450hrt stopped mid run
Use your multi meter check continuity on motor leads if you get about 1 to 1.5 ohms if not leads may have open. You may also need to do calibration if the above check a ok.
Posted on Apr 15, 2010
Ranglo
  • 1194 Answers
SOURCE: i am getting a C4 on my T9350
Thanks for using Fixya.
C4 error indicates Elevation error (signal lost).
To remove it, check condition of all cables and cable connections and recalibrate
Posted on Apr 19, 2010
maxtreadmill
  • 832 Answers
SOURCE: Why won't my vision fitness simple T9500 run? I
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Posted on Jun 14, 2010
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
What does error code R5232 Failed mean on Vision Fitness T9600HRT treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 04, 2016 | Vision Fitness Exercise & Fitness
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
Jan 10, 2016 | Vision Fitness T9200 Treadmill
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
My vision fitness t9450hrt stopped mid run yesterday and the belt wont move..the inclene still works and everything else works fine i have took the cover off checked the drive belt from the motor and it is...
Apr 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
Have the same problem with my Everyoung Treadmill EY88800K. Display was zapped with static and treadmill became inoperable. Great condition and hate to toss out. Any hope?
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Dec 28, 2009 | Exercise & Fitness
Dmm Vision Fitness T9500 Treadmill Logo
70 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
