Question about Plumbing
Dayton sump pump- replacing switch and need wiring diagram
ranger25
  • 72 Answers
SOURCE: dayton heater/ need wiring diagram /
What's the model number?
Posted on Jan 28, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
Posted on May 14, 2009
SOURCE: Yes I need the wiring diagram for Dayton model
wiring Mistral Speed Regulator Model MCF48D/6OD 220-240V
Posted on Sep 07, 2009
  • 4088 Answers
SOURCE: i need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Posted on Jun 23, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
I have a Dayton 5X848N relay switch that needs connected to a well pump. how is it wired
go to www.ehow.com and type in the search box
"relay switch wiring"
and you will pull up 6 web pages of click on the post articles
on how to wire in a relay. somewheres in all that techinical info
someone will be writing about a relay just like yours & be giving step by step instruction as well as tools needed to do job.
try typing in search box---" how to wire dayton 5x848n relay into well pump.
You should also have the make and model of the well pump handy on paper as you will need this to find out where relay goes to pump motor.
If you need more specific info type in search box
*how 2 wire dayton 5x848n relay into make & model well pump*
try that on google.com.;bing.com;ask.com;yahoo.com as well as
ehow.com
they all have search box on upper right coner of web page & they all answer questions with pre writen info.
Oct 12, 2013 | Dayton Dryers
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
May 21, 2013 | Pool & Spa
How to install a three speed switch on a dayton 5m188f motor fan?
Is it 3 wire or 4 wire ? And what color of wires are they ? If you look at old switch it should have numbers or letters to signify wire placement follow diagram from old to new and all should be good .
Jan 24, 2012 | Dayton (5M188) Fan
I have a dayton 3/4 hp fan motor. I need to change voltage from 230 to 115. Where can I get a wiring diagram showing the wire changes that I need to make. I have done this before but forgot which wires...
There are many different types of motors. you should have a diagram on the inside of the wiring compartment cover. This is a dayton diagram, but I can't be sure it is the same as the motor you have.Notice line terminals remain the same, but that the internal wires change terminals.
Aug 05, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I need a wiring diagram for a farm duty 6k714k
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Ray
Dec 07, 2008 | Dayton (3E379) Heater
Plumbing Logo
719 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
